跳转到主内容
加入维修社区 - 创建账户
Edifier W820NB Plus I/O Board Replacement
你所需要的
    1. Edifier W820NB Plus I/O Board Replacement, Ear Pads: 步骤 1 中的图像 1,1
      • Start with the headphones face up and the earpads visible.
      询问修复机器人
      添加评论
    2. Edifier W820NB Plus I/O Board Replacement: 步骤 2 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 2 中的图像 2,2
      • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
      询问修复机器人
      添加评论
    3. Edifier W820NB Plus I/O Board Replacement: 步骤 3 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 3 中的图像 2,2
      • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
      • Repeat this procedure for the other side if necessary.
      询问修复机器人
      添加评论
    4. Edifier W820NB Plus I/O Board Replacement: 步骤 4 中的图像 1,1
      • Repeat for the other side if necessary.
      询问修复机器人
      添加评论
    1. Edifier W820NB Plus I/O Board Replacement, Drivers: 步骤 5 中的图像 1,1
      • Identify the driver you wish to replace.
      • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
      询问修复机器人
      添加评论
    2. Edifier W820NB Plus I/O Board Replacement: 步骤 6 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 6 中的图像 2,2
      • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
      询问修复机器人
      添加评论
    3. Edifier W820NB Plus I/O Board Replacement: 步骤 7 中的图像 1,3 Edifier W820NB Plus I/O Board Replacement: 步骤 7 中的图像 2,3 Edifier W820NB Plus I/O Board Replacement: 步骤 7 中的图像 3,3
      • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
      • Insert a Jimmy in the seam between the driver assembly and driver housing.
      • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
      询问修复机器人
      添加评论
    4. Edifier W820NB Plus I/O Board Replacement: 步骤 8 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 8 中的图像 2,2
      • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
      询问修复机器人
      添加评论
    5. Edifier W820NB Plus I/O Board Replacement: 步骤 9 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 9 中的图像 2,2
      • Skip this step if you are completing a battery replacement.
      • Repeat the procedure for the other driver if necessary.
      • Desolder the four driver connections from the motherboard.
      • Remove the driver assembly.
      询问修复机器人
      添加评论
    1. Edifier W820NB Plus I/O Board Replacement, I/O Board: 步骤 10 中的图像 1,3 Edifier W820NB Plus I/O Board Replacement, I/O Board: 步骤 10 中的图像 2,3 Edifier W820NB Plus I/O Board Replacement, I/O Board: 步骤 10 中的图像 3,3
      • Use a Philllips #0 screwdriver to remove the 2 mm screws that secure the I/O board.
      询问修复机器人
      添加评论
    2. Edifier W820NB Plus I/O Board Replacement: 步骤 11 中的图像 1,3 Edifier W820NB Plus I/O Board Replacement: 步骤 11 中的图像 2,3 Edifier W820NB Plus I/O Board Replacement: 步骤 11 中的图像 3,3
      • Pry out the power and volume buttons cover using a Jimmy.
      询问修复机器人
      添加评论
    3. Edifier W820NB Plus I/O Board Replacement: 步骤 12 中的图像 1,2 Edifier W820NB Plus I/O Board Replacement: 步骤 12 中的图像 2,2
      • Pull the daughter board out.
      • Note that the connections (both in the front and back) will need to be desoldered.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
Happy Zhang
于03/21/25注册
438 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-7, Botvin Spring 2025 UMass Dartmouth, Team 2-7, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S2G7
3 名成员
创作了23篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 602
