Dyson Pure Cool AM11 Oscillation Motor Replacement
简介
转到步骤 1If, after consulting the troubleshooting page, you believe your oscillation motor has blown, this guide will walk you through accessing it to do your own repair/replacement. The oscillation motor is wired directly into the devices main circuitry and thus requires knowledge and experience to replace. This guide will simply cover how to access and remove it.
Using a Torx T20 Screwdriver, remove the screw in the center of the base.
Remove the two screws connected to the rotation arm.
There are instructions missing here. The black middle panel once removed gives access to two screws that are connected to the rotation arm (visible in the photo above), these need to be removed.
Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
另外一个人完成了本指南。
