跳转到主内容
DualShock 4 Right Analog Stick Replacement
你所需要的
  1. DualShock 4 Right Analog Stick Replacement, Check your controller model: 步骤 1 中的图像 1,1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 Right Analog Stick Replacement, Unfasten the rear case: 步骤 2 中的图像 1,2 DualShock 4 Right Analog Stick Replacement, Unfasten the rear case: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 Right Analog Stick Replacement, Remove the L1 button: 步骤 3 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Remove the L1 button: 步骤 3 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Remove the L1 button: 步骤 3 中的图像 3,3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 Right Analog Stick Replacement, Remove the R1 button: 步骤 4 中的图像 1,1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 Right Analog Stick Replacement, Unclip the rear case: 步骤 5 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Unclip the rear case: 步骤 5 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Unclip the rear case: 步骤 5 中的图像 3,3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 Right Analog Stick Replacement: 步骤 6 中的图像 1,3 DualShock 4 Right Analog Stick Replacement: 步骤 6 中的图像 2,3 DualShock 4 Right Analog Stick Replacement: 步骤 6 中的图像 3,3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 Right Analog Stick Replacement: 步骤 7 中的图像 1,1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 Right Analog Stick Replacement: 步骤 8 中的图像 1,3 DualShock 4 Right Analog Stick Replacement: 步骤 8 中的图像 2,3 DualShock 4 Right Analog Stick Replacement: 步骤 8 中的图像 3,3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 Right Analog Stick Replacement, Remove the rear case: 步骤 9 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Remove the rear case: 步骤 9 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Remove the rear case: 步骤 9 中的图像 3,3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 Right Analog Stick Replacement: 步骤 10 中的图像 1,1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 Right Analog Stick Replacement: 步骤 11 中的图像 1,3 DualShock 4 Right Analog Stick Replacement: 步骤 11 中的图像 2,3 DualShock 4 Right Analog Stick Replacement: 步骤 11 中的图像 3,3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 Right Analog Stick Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Disconnect the interconnect cable: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 Right Analog Stick Replacement, Disconnect the battery: 步骤 13 中的图像 1,2 DualShock 4 Right Analog Stick Replacement, Disconnect the battery: 步骤 13 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
    • Only pull on the head of the connector—don't pull on the cable itself.
  14. DualShock 4 Right Analog Stick Replacement, Remove the battery: 步骤 14 中的图像 1,1
    • Remove the battery.
  15. DualShock 4 Right Analog Stick Replacement, Remove the reset button extension: 步骤 15 中的图像 1,2 DualShock 4 Right Analog Stick Replacement, Remove the reset button extension: 步骤 15 中的图像 2,2
    • Grab and remove the reset button extension from its recess in the battery bracket.
  16. DualShock 4 Right Analog Stick Replacement, Remove the battery bracket: 步骤 16 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Remove the battery bracket: 步骤 16 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Remove the battery bracket: 步骤 16 中的图像 3,3
    • Locate the two clips securing the battery bracket to the motherboard.
    • Insert the point of your spudger into the opening behind the right bracket clip.
    • Depress the clip to disengage it from the motherboard.
    • Lift up the right edge of the battery bracket.
  17. DualShock 4 Right Analog Stick Replacement: 步骤 17 中的图像 1,2 DualShock 4 Right Analog Stick Replacement: 步骤 17 中的图像 2,2
    • Insert the point of your spudger in the opening behind the left bracket clip.
    • Remove the battery bracket.
  18. DualShock 4 Right Analog Stick Replacement, Disconnect the touch pad: 步骤 18 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Disconnect the touch pad: 步骤 18 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Disconnect the touch pad: 步骤 18 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
    • Use tweezers or your fingers to disconnect the cable using its blue pull tab.
  19. DualShock 4 Right Analog Stick Replacement, Unfasten the motherboard: 步骤 19 中的图像 1,1
    • Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
  20. DualShock 4 Right Analog Stick Replacement, Remove the motherboard: 步骤 20 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Remove the motherboard: 步骤 20 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Remove the motherboard: 步骤 20 中的图像 3,3
    • Be careful not to strain the vibration motor cables. Follow this guide to re-solder the vibration motors if they break off the motherboard.
    • Lift the motherboard from the midframe.
    • Guide the analog stick covers through their cutouts in the front case.
    • Flip the motherboard over the bottom of the controller, leaving the vibration motor cables attached.
  21. DualShock 4 Right Analog Stick Replacement, Right Analog Stick: 步骤 21 中的图像 1,3 DualShock 4 Right Analog Stick Replacement, Right Analog Stick: 步骤 21 中的图像 2,3 DualShock 4 Right Analog Stick Replacement, Right Analog Stick: 步骤 21 中的图像 3,3
    • These are the solder connections that will need to be desoldered. Since the board is upside down, left will become right.
    • Use a desoldering wick and flux to melt and remove the solder
    • This may take a bit of practice since all the solder will have to be removed. It does help to pull a bit on the joystick while melting the solder and using the wick.
  22. DualShock 4 Right Analog Stick Replacement: 步骤 22 中的图像 1,3 DualShock 4 Right Analog Stick Replacement: 步骤 22 中的图像 2,3 DualShock 4 Right Analog Stick Replacement: 步骤 22 中的图像 3,3
    • Once all the contacts are desoldered, the old joystick can be removed.
    • Check that all the holes are cleared of old solder. Hypodermic needles as well as very small drill bits can be used to clear the holes.
    • Insert the new joystick into the circuit board. Make sure it is properly seated and that all the contacts line up with the holes in the circuit board.
  23. DualShock 4 Right Analog Stick Replacement: 步骤 23 中的图像 1,3 DualShock 4 Right Analog Stick Replacement: 步骤 23 中的图像 2,3 DualShock 4 Right Analog Stick Replacement: 步骤 23 中的图像 3,3
    • Double check to make sure the joystick is seated properly.
    • Solder all the contacts to the board.
    • Here is the board after the repair. All that is left is to clean off the old flux with some isopropyl alcohol.
结论
33等其他人完成本指南。
oldturkey03
于09/29/10注册
789,677 声望
创作了119篇指南
团队
Global Fixers Global Fixers 的会员
Community
34 名成员
创作了597篇指南
14条评论
I just tried to remove both joystick and replaced them but unfortunately only one joystick works and that one that works it's stuck on and only moves in one direction.
Juan Hernandez - 回复
I've not been able to actually get the solder out, would love any suggestions or tips.
James Napoli - 回复
send me a couple of pictures on what your repair looks like thus far. Send them to my email. Click on my username and my email address is on my profile. Let's see what you got so far.
oldturkey03 -
This is a very difficult repair, what this guy didn't mention is you need a very expensive solder station with an electric solder sucker. The solder needs removing and it's nearly impossible without damaging the tracking.
Dave bolton - 回复
You definitely need some soldering experience but the repairability is not that difficult. The soldering points are big enough for any cheap ($40) soldering iron can get too. As for removing them, it helps to use flux and also a soldering wick to absorb all the old solder. It is not easy but not the most difficult repair. P.S you do not need the expensive soldering stating with hot air etcetera. This works perfectly as it get hot beyond the required point to melt the solder
Eyob Grainge -
添加评论
浏览统计数据:
过去 24 小时: 55
过去 7 天: 432
过去 30 天: 2,099
总计 158,854
