跳转到主内容
加入维修社区 - 创建账户
DualShock 3 Trigger Buttons Replacement
你所需要的
    1. DualShock 3 Trigger Buttons Replacement, Rear Cover: 步骤 1 中的图像 1,1
      • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
      添加评论
    2. DualShock 3 Trigger Buttons Replacement: 步骤 2 中的图像 1,1
      • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
      添加评论
    3. DualShock 3 Trigger Buttons Replacement: 步骤 3 中的图像 1,2 DualShock 3 Trigger Buttons Replacement: 步骤 3 中的图像 2,2
      • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
      • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
      • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
      添加评论
    1. DualShock 3 Trigger Buttons Replacement, Trigger Buttons: 步骤 4 中的图像 1,1
      • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
      询问修复机器人
      添加评论
    2. DualShock 3 Trigger Buttons Replacement: 步骤 5 中的图像 1,2 DualShock 3 Trigger Buttons Replacement: 步骤 5 中的图像 2,2
      • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
      添加评论
    3. DualShock 3 Trigger Buttons Replacement: 步骤 6 中的图像 1,2 DualShock 3 Trigger Buttons Replacement: 步骤 6 中的图像 2,2
      • Pull the black plastic trigger retainer slightly away from the front cover.
      • Pull the #1 button out of the front cover.
      询问修复机器人
      添加评论
    4. DualShock 3 Trigger Buttons Replacement: 步骤 7 中的图像 1,2 DualShock 3 Trigger Buttons Replacement: 步骤 7 中的图像 2,2
      • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
      • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
      添加评论
结论
取消:我没有完成这个指南。
78等其他人完成本指南。
9指南评论
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
Will Foss - 回复 分享
The little green eletronic ribben where is it supposed to go?
dmall - 回复 分享
The #00 screwdriver is working better
Leopold287 - 回复 分享
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Sidney Klemkosky - 回复 分享
Is there a way I can buy trigger retainers?
CynicalSheep - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 51
过去 7 天: 282
过去 30 天: 1,357
总计 141,570
