跳转到主内容
加入维修社区 - 创建账户
Disassembling the Teac DC-D2831
你所需要的
    1. Disassembling the Teac DC-D2831, Disassembling the Teac DC-D2831: 步骤 1 中的图像 1,1
      • Make sure the device is turned off and unplugged. This will eliminate the danger of getting electrocuted while repairing the device or damaging components.
      询问修复机器人
      添加评论
    2. Disassembling the Teac DC-D2831: 步骤 2 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 2 中的图像 2,2
      在这个步骤中使用的工具:
      • Lift the lid to get to the turntable.
      • Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
      • The snap-ring is hard to remove so be patient and don't be afraid to use some force.
      • Feel free to use whatever tool(s) that will remove the snap-ring. The above list of tools are just a suggestions.
      询问修复机器人
      添加评论
    3. Disassembling the Teac DC-D2831: 步骤 3 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 3 中的图像 2,2
      • Gently lift the turntable from the rest of the device.
      • If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
      询问修复机器人
      添加评论
    4. Disassembling the Teac DC-D2831: 步骤 4 中的图像 1,1
      • Remove the screws on the side of the device using a Phillips #2 screwdriver.
      • When removing the screws, take note of which screws go where.
      • 27.0mm
      • 19.8mm
      • 12.0mm
      询问修复机器人
      添加评论
    5. Disassembling the Teac DC-D2831: 步骤 5 中的图像 1,2 Disassembling the Teac DC-D2831: 步骤 5 中的图像 2,2
      • Lift the base that the turntable was resting on from the rest of the device.
      • Remove the base slowly so to not sever the connection with the wire attached from the base to the circuit board.
      询问修复机器人
      添加评论
    6. Disassembling the Teac DC-D2831: 步骤 6 中的图像 1,1
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 的会员
CPSU-PROPEN-F12S2G61
4 名成员
创作了20篇指南
3指南评论
How to remove lid from CD-D2831
jfranklinhamm - 回复 分享
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
Joanna Chavez - 回复 分享
Does anyone know how to fix the cd player?
Mine won't open when the button is pressed. All other features work, Radio, LP player and Tape decks.
There are no disks stuck in the tray, I checked.
Thxs
Boxterfan - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 41
总计 5,492
