当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
With the case split, you can see the LCD in its holder. The LCD is simply laid into the holder.
Gently remove the LCD from the holder and just flip it to the side. Do not remove it yet. You will have to loosen the clip on the connector. Use your fingernails to move it in the opposite direction from the LCD, this will open it up.
Remove the four screws from the LCD holder.
这个步骤还没有翻译 帮忙翻译一下
LCD holder removed from logic board
disconnect the ribbon cable from the logic board. This one requires to move the brown tabs on the left and right hands side in an upward direction. They should just slide up by about an 1/8th of an inch. this will free the ribbon cable.
With the ribbon cable disconnected, remove the front case.
2等其他人完成本指南。
