跳转到主内容
Dell Vostro 5510 SSD Card Replacement
Alexandra Moon
Alexandra Moon2 其他贡献者
最后更新于 June 12, 2023
没有估计
中等
Use this guide to remove/replace your SSD card from your computer.
Before removing the SSD, read through your computer's user manual to familiarize yourself with the safety guidelines. This is to protect your computer from potential damage and ensures your personal safety.
你所需要的
工具
查看更多...
  1. Dell Vostro 5510 SSD Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 SSD Card Replacement: 步骤 2 中的图像 1,1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 SSD Card Replacement: 步骤 3 中的图像 1,3 Dell Vostro 5510 SSD Card Replacement: 步骤 3 中的图像 2,3 Dell Vostro 5510 SSD Card Replacement: 步骤 3 中的图像 3,3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 SSD Card Replacement: 步骤 4 中的图像 1,3 Dell Vostro 5510 SSD Card Replacement: 步骤 4 中的图像 2,3 Dell Vostro 5510 SSD Card Replacement: 步骤 4 中的图像 3,3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 SSD Card Replacement, SSD Card: 步骤 5 中的图像 1,1
    • Locate the SSD card.
  6. Dell Vostro 5510 SSD Card Replacement: 步骤 6 中的图像 1,1
    • Remove the screw (M2x3mm) with the screwdriver.
  7. Dell Vostro 5510 SSD Card Replacement: 步骤 7 中的图像 1,1
    • Grab the elevated side of the card.
    • Remove the card from the card slot.
结论
Alexandra Moon
于02/09/23注册
97 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 10
总计 187
