跳转到主内容
Dell Vostro 14 3468 Memory Module Replacement
Johnathan Hammond
Johnathan Hammond 另一个贡献者
最后更新于 November 10, 2019
15 - 30 分钟
中等
社区贡献指南
你所需要的
工具
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Dell Vostro 14 3468 Memory Module Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 14 3468 Memory Module Replacement, Optical-Disk Drive: 步骤 2 中的图像 1,1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 14 3468 Memory Module Replacement, KeyBoard: 步骤 3 中的图像 1,1
    • Release the keyboard by prying on the keyboard release tabs using a plastic scribe [1].
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [2].
  4. Dell Vostro 14 3468 Memory Module Replacement: 步骤 4 中的图像 1,1
    • Disconnect the keyboard cable from the system board.
    • Lift the keyboard cable to remove it from the computer.
  5. Dell Vostro 14 3468 Memory Module Replacement, Base Cover: 步骤 5 中的图像 1,1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the screws inside the palmrest [2].
  6. Dell Vostro 14 3468 Memory Module Replacement: 步骤 6 中的图像 1,1
    • Remove the screws that secure the base cover to the computer
  7. Dell Vostro 14 3468 Memory Module Replacement: 步骤 7 中的图像 1,1
    • Pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  8. Dell Vostro 14 3468 Memory Module Replacement, Memory Module: 步骤 8 中的图像 1,1
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
结论
另外一个人完成了本指南。
Johnathan Hammond
于02/28/18注册
45,237 声望
创作了408篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 952
