跳转到主内容
Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement
Austin Blakely
Austin Blakely
最后更新于 January 3, 2022
20分钟
中等
This guide will show you how to replace the Wi-Fi card in a Dell Inspiron 7573 2-in-1 computer. The Wi-Fi card facilitates the connection of the computer to wireless networks such as your internet connection. If you are having trouble starting or maintaining connections and have ruled out issues with your modem, router, and internet service provider, your Wi-Fi card may be at fault. Use this guide to help you replace it!
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #00 Screwdriver
  1. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 1,2 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Make sure computer is off before you begin.
    • Remove the four 5 mm screws from the bottom edge of the laptop using a Phillips #00 screwdriver.
    • Loosen the remaining six captive screws from the bottom cover with a Phillips #00 screwdriver.
  2. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Using a spudger, pry off the bottom cover by gently prying from corner to corner in order to disengage the plastic clips.
    • Lift off the bottom cover.
    • After the base cover is removed, your laptop should look similar as depicted in the images provided.
  3. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 3 中的图像 1,1
    • Remove the four 3 mm screws holding the battery in place with a Phillips #00 screwdriver.
  4. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 4 中的图像 1,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 4 中的图像 2,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement: 步骤 4 中的图像 3,3
    • Using the pull tab, disconnect the battery cable from the system board.
    • Lift the battery out from the laptop case.
  5. Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 5 中的图像 1,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 5 中的图像 2,3 Dell Inspiron 7573 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 5 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the 3 mm screw that secures the wireless-card bracket and wireless card to the I/O board.
    • Lift the wireless-card bracket off of the wireless card.
    • Disconnect the white and black antenna cables from the wireless card.
    • Slide and remove the wireless card from the wireless card slot.
结论
Austin Blakely
于03/11/19注册
21,277 声望
创作了53篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,455篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 15
总计 392
