跳转到主内容
Dell Inspiron 5100 PP07L Hard Drive Replacement
May Chauvin
May Chauvin9 其他贡献者
最后更新于 January 22, 2020
30秒 - 2分钟
非常容易
You will learn how to remove the hard drive.
  1. Dell Inspiron 5100 PP07L Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • With the lid closed, place the laptop upside-down on a flat surface.
  2. Dell Inspiron 5100 PP07L Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 5100 PP07L Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Remove the two 5.8mm screws securing the hard drive bay.
    • If the computer was right-side-up and rotated for use, the bay would be found in the rear left corner.
  3. Dell Inspiron 5100 PP07L Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the plastic bay handle and slide outwards to remove.
结论
4等其他人完成本指南。
May Chauvin
于04/14/11注册
201 声望
创作了6篇指南
团队
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 的会员
CPSU-MANESS-S11S12G34
4 名成员
创作了6篇指南
1指南评论
Can someone please tell me which type of hard drive is it?
Nintendo Fan Unity - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 49
总计 21,797
