跳转到主内容
Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 23, 2019
9 - 15 分钟
简单
社区贡献指南
In this guide, we will be showing you how to remove and replace the Hard-Drive Assembly.
你所需要的
工具
  1. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: 步骤 1 中的图像 1,1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Hard-Drive Assembly: 步骤 2 中的图像 1,1
    • Slide the hard-drive assembly forward to disconnect the hard-drive assembly from the system board.
  3. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Assembly: 步骤 3 中的图像 1,1
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Remove the Screws: 步骤 4 中的图像 1,1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Lifting the Hard Drive Bracket: 步骤 5 中的图像 1,1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Align the Screw Holes: 步骤 6 中的图像 1,1
    • Align the screw holes on the hard-drive bracket with the screw holes on the NEW hard drive.
  7. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: 步骤 7 中的图像 1,1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  8. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: 步骤 8 中的图像 1,1
    • Slide and place the hard-drive assembly in the hard-drive bay.
  9. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Sliding the Assembly: 步骤 9 中的图像 1,1
    • Slide the hard-drive assembly backward to connect the hard-drive assembly to the system board.
  10. Dell Inspiron 15R 5521 Hard-Drive Assembly Replacement, Replace the Screws: 步骤 10 中的图像 1,1
    • Replace the screws that secure the hard-drive assembly to the computer base.
终点
Terrence15
于12/18/17注册
79,555 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 973
