跳转到主内容
Dell Inspiron 15-5559 CD Drive Replacement
Kyla Ward
Kyla Ward 另一个贡献者
最后更新于 August 8, 2019
4 - 5 分钟
简单
Before you begin, you will need a Phillips #1 screwdriver and a black nylon spudger to complete the CD Drive removal. You will also need to remove the battery of your device before you begin.
你所需要的
配件
工具
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
查看更多...
  1. Dell Inspiron 15-5559 CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,1
    • Use the Philips #1 to remove the two (2) 2.5x8mm screws that anchor the CD Drive.
    • It is important that the correct screw driver is used to remove the screws to prevent damaging them.
  2. Dell Inspiron 15-5559 CD Drive Replacement: 步骤 2 中的图像 1,3 Dell Inspiron 15-5559 CD Drive Replacement: 步骤 2 中的图像 2,3 Dell Inspiron 15-5559 CD Drive Replacement: 步骤 2 中的图像 3,3
    • Place the spudger at the spot indicated by the red circle.
    • Use your hand to pull the CD drive out while using the spudger as leverage to push the CD drive out.
结论
2等其他人完成本指南。
Kyla Ward
于03/19/18注册
649 声望
创作了4篇指南
团队
Baylor, Team S5-G5, Williams Spring 2018 Baylor, Team S5-G5, Williams Spring 2018 的会员
BU-WILLIAMS-S18S5G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 27
总计 1,712
