跳转到主内容
Dell Inspiron 15-5558 Screen Replacement
Adam Lourenco
Adam Lourenco3 其他贡献者
最后更新于 December 21, 2017
15分钟
中等
If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: 步骤 2 中的图像 1,1
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
  3. Dell Inspiron 15-5558 Screen Replacement: 步骤 3 中的图像 1,2 Dell Inspiron 15-5558 Screen Replacement: 步骤 3 中的图像 2,2
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: 步骤 4 中的图像 1,2 Dell Inspiron 15-5558 Screen Replacement, Screen: 步骤 4 中的图像 2,2
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
  5. Dell Inspiron 15-5558 Screen Replacement: 步骤 5 中的图像 1,3 Dell Inspiron 15-5558 Screen Replacement: 步骤 5 中的图像 2,3 Dell Inspiron 15-5558 Screen Replacement: 步骤 5 中的图像 3,3
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: 步骤 6 中的图像 1,3 Dell Inspiron 15-5558 Screen Replacement: 步骤 6 中的图像 2,3 Dell Inspiron 15-5558 Screen Replacement: 步骤 6 中的图像 3,3
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
结论
7等其他人完成本指南。
Adam Lourenco
于10/19/17注册
793 声望
创作了5篇指南
团队
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 UMass Dartmouth, Team S3-G4, Bailey Fall 2017 的会员
UMASSD-BAILEY-F17S3G4
3 名成员
创作了5篇指南
3条评论
Where can I buy the screen from?
wardak_90 - 回复
How many pins is the screen connector? 30? 40?
Adrian Lewis - 回复
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
James Diamond - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 30
总计 4,836
