跳转到主内容
Dell Inspiron 15-3521 Keyboard Replacement
Andrew Dippre
Andrew Dippre5 其他贡献者
最后更新于 January 3, 2023
5 - 10 分钟
简单
This guide will provide the steps necessary to replace the keyboard for the Dell Inspiron 15-3521. This is an easy fix, and it will save you money by negating the need to purchase a new device. In three easy steps, your device will work like new.
If you're trying to troubleshoot your computer, please follow this link: troubleshooting page. It is a very resourceful link and it can save you from scrapping a perfectly capable device.
Keyboards can last for up to ten years depending on how heavily they've been used. If your keys are not working, or you find your keys are sticking as you type, it may be time for a replacement. If you maintain your keyboard by replacing it when necessary, you can save your device, money, and time.
Repairing your keyboard as parts break can make mechanical keyboards last much longer.
你所需要的
  1. Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 步骤 1 中的图像 1,3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 步骤 1 中的图像 2,3 Dell Inspiron 15-3521 Keyboard Replacement, Remove the Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over.
    • Slide the latches toward the outside of the laptop to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 步骤 2 中的图像 1,3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 步骤 2 中的图像 2,3 Dell Inspiron 15-3521 Keyboard Replacement, Removing Keyboard: 步骤 2 中的图像 3,3
    • Flip laptop right side up
    • Using a flat head screwdriver, depress locking tabs holding keyboard into place
    • Using a spudger, pry the keyboard from the laptop, giving room to access with hands.
    • Using hands, remove keyboard completely from laptop body, leaving only the connecting cord that attaches the keyboard to the laptop.
  3. Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 1,3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 2,3 Dell Inspiron 15-3521 Keyboard Replacement, Disconnecting the Keyboard Cable: 步骤 3 中的图像 3,3
    • To disconnect the keyboard, locate the keyboard cable locking mechanism.
    • Open the locking mechanism by gently pulling up.
    • Slide out the keyboard cable from the interface to separate the keyboard form the laptop.
结论
13等其他人完成本指南。
Andrew Dippre
于10/13/14注册
2,902 声望
创作了7篇指南
团队
Clemson, Team 3-1, Benson Fall 2014 Clemson, Team 3-1, Benson Fall 2014 的会员
CLEM-BENSON-F14S3G1
4 名成员
创作了9篇指南
1指南评论
Awesome post. Thanks
Derek Morgan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 22,737
