Dell Inspiron 15 7579 Battery Replacement
简介
转到步骤 1If your laptop is unresponsive or you have a consistently low battery life, we recommend starting with our troubleshooting guide. If those tips don't solve your problem, then follow this guide to replace your battery.
你所需要的
Remove the two 7.8 mm long screws on the left side of the battery with the Phillips #1 screwdriver.
Pull out the fabric clip that attaches the battery to the main board from the connector by hand.
Remove the battery from the device.
Super easy 3minute battery swap, removing and replacing housing screws is what all the work here is.
My Mom is super happy she no longer has to be plugged in to use her laptop.
Thank you ifixit 😊✌️
10等其他人完成本指南。
2指南评论
Thanks! Very helpful and to the point!
You ARE TECHNICALLY missing one step however, removing the fabric ribbon from the old battery at the end. Yes, it seems like common sense but…
Anyways, thanks.
Thanks for the help, worked well.
Remember the connector needs to be removed from the old battery and re-installed in the new. I used a small slotted screwdriver.
A. Holness
June 7, 2020
