跳转到主内容
Dell Inspiron 14 Gaming 7466 Display Assembly Replacement
Terrence15
Terrence15 另一个贡献者
最后更新于 November 18, 2019
8 - 30 分钟
简单
社区贡献指南
In this guide, we will show you how to remove and replace the Display Assembly.
你所需要的
工具
  1. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Camera Cable: 步骤 1 中的图像 1,1
  2. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peeling the Camera Cable: 步骤 2 中的图像 1,1
    • Peel off the camera cable from the computer base.
  3. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Antenna Cables: 步骤 3 中的图像 1,1
    • Remove the antenna cables from the routing guides on the computer base.
  4. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screw: 步骤 4 中的图像 1,1
    • Remove the screw (M2x3) that secures the display-cable bracket to the system board.
  5. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Cable Bracket: 步骤 5 中的图像 1,1
    • Lift the display-cable bracket off the system board.
  6. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Disconnecting the Display Cable: 步骤 6 中的图像 1,1
    • Using the pull-tab, disconnect the display cable from the system board.
  7. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Peel off the Display Cable: 步骤 7 中的图像 1,1
    • Peel off the display cable from the computer base.
  8. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: 步骤 8 中的图像 1,1
    • Remove the two screws (M2x3) that secure the display assembly to the computer base.
  9. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: 步骤 9 中的图像 1,1
    • Remove the two screws (M2.5x5) that secure the display assembly to the computer base.
  10. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Open the Display: 步骤 10 中的图像 1,1
    • Turn the computer over and open the display.
  11. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Remove the Screws: 步骤 11 中的图像 1,1
  12. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Lifting the Display Assembly: 步骤 12 中的图像 1,1
    • Lift the display assembly off the computer base.
  13. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Holes: 步骤 13 中的图像 1,1
    • Align the screw holes on the NEW display assembly with the screw holes on the computer base.
  14. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: 步骤 14 中的图像 1,1
    • Replace the two screws (M2.5x5) that secure the display assembly to the computer base.
  15. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: 步骤 15 中的图像 1,1
    • Close the display and turn the computer over.
  16. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screws: 步骤 16 中的图像 1,1
    • Replace the two screws (M2x3) that secure the display assembly to the computer base.
  17. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Adhering the Cables: 步骤 17 中的图像 1,1
    • Adhere the display cable and the camera cable to the computer base.
  18. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Connect the Display Cable: 步骤 18 中的图像 1,1
    • Connect the display cable and camera cable to the system board.
  19. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Align the Screw Hole: 步骤 19 中的图像 1,1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  20. Dell Inspiron 14 Gaming 7466 Display Assembly Replacement, Replace the Screw: 步骤 20 中的图像 1,1
    • Replace the screw (M2x3) that secures the display cable bracket to the system board.
终点
Terrence15
于12/18/17注册
79,585 声望
创作了441篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 129
