跳转到主内容
Dell Inspiron 13 7378 Heat Sink Replacement
Javier Perez
Javier Perez6 其他贡献者
最后更新于 May 23, 2023
15 - 30 分钟
中等
The Dell Inspiron 13 7378 is a widely used laptop model, however, it is not immune to technical issues. One of the most prevalent problems faced by this device is CPU overheating. To mitigate this issue, it is crucial to replace the cooling system and prevent any harm to the internal components of the laptop. This guide will provide you with step-by-step instructions on how to perform this maintenance procedure in a professional manner.
你所需要的
工具
查看更多...
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 2 中的图像 1,2 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 1,3 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 2,3 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 3 中的图像 3,3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: 步骤 4 中的图像 1,1
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 5 中的图像 1,2 Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 5 中的图像 2,2
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: 步骤 6 中的图像 1,1
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
结论
Replace the back cover to complete the process.
3等其他人完成本指南。
Javier Perez
于02/08/22注册
277 声望
创作了2篇指南
团队
Gateway, Team 1-3, Saknee Spring 2022 Gateway, Team 1-3, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G3
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 375
