跳转到主内容
Dell Inspiron 11-3164 Screen Replacement
Michael Kendziora
Michael Kendziora2 其他贡献者
最后更新于 May 28, 2018
25 - 45 分钟
中等
更好的介绍
你所需要的
  1. Dell Inspiron 11-3164 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Dell Inspiron 11-3164 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Lay the laptop flat with its bottom up exposing the screws holding it together. Unscrew these eight screws with a JIS #1 screwdriver and put them aside.
    • Use your screw driver to pry off the plastic cover exposing the last screw in the middle.
    • Remove the screw and save the plastic cover to put back on later when done.
  2. Dell Inspiron 11-3164 Screen Replacement: 步骤 2 中的图像 1,1
    • Remove this one screw with the JIS #1 screwdriver in order to take of the holding plate for the wifi card adapter. Then remove the adapter.
    • Unscrew these two screws with a JIS#1 screwdriver.
    • Peel back the two metal brackets to remove the screen.
结论
团队
USF Tampa, Team S6-G4, Eyestone Spring 2018 USF Tampa, Team S6-G4, Eyestone Spring 2018 的会员
USFT-EYESTONE-S18S6G4
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 198
