跳转到主内容
Coby DVD209 Circuit Board for Buttons Replacement
Yufay Chow
Yufay Chow7 其他贡献者
最后更新于 January 28, 2014
10 - 20 分钟
中等
你所需要的
配件
工具
查看更多...
  1. Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 1,3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 2,3 Coby DVD209 Circuit Board for Buttons Replacement, The bottom portion of the DVD player: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Press the eject button to view the laser inside.
    • Using the blue plastic tool and the tweezers, remove the ribbon cable.
  2. Coby DVD209 Circuit Board for Buttons Replacement: 步骤 2 中的图像 1,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 2 中的图像 2,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 2 中的图像 3,3
    • Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
    • Do not lift the top of the DVD player too quickly because there are wires attached on the inside.
    • Pry the top of the device open from the right side where the buttons are located.
  3. Coby DVD209 Circuit Board for Buttons Replacement: 步骤 3 中的图像 1,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 3 中的图像 2,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 3 中的图像 3,3
    • When pulling the ribbon cables out, make sure not to pull by the wires, as this can cause damage to them.
    • Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
  4. Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: 步骤 4 中的图像 1,2 Coby DVD209 Circuit Board for Buttons Replacement, Circuit Board for Buttons: 步骤 4 中的图像 2,2
    • Take the top portion of the DVD player and orient the device as shown in the first picture.
    • Remove the four 0.2" screws circled in red.
  5. Coby DVD209 Circuit Board for Buttons Replacement: 步骤 5 中的图像 1,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 5 中的图像 2,3 Coby DVD209 Circuit Board for Buttons Replacement: 步骤 5 中的图像 3,3
    • Losen the screw circled in red.
    • The screw will not come out of the plastic knob.
    • Turn the plastic knob 90 degrees to the right so that the cable comes out freely.
结论
Yufay Chow
于01/23/12注册
92 声望
创作了4篇指南
团队
Cal Poly, Team 10-36, Amido Winter 2012 Cal Poly, Team 10-36, Amido Winter 2012 的会员
CPSU-AMIDO-W12S10G36
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 480
