Canon Rebel T5i Back Cover Replacement
简介
转到步骤 1Remove the back cover is the first step for accessing most components on the camera. It is also useful if you need to replace the back cover itself or the attached LCD screen.
Before beginning, remove the battery and SD card from the camera.
Using your thumbs, push up on the eyepiece to remove it.
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
Using a plastic opening pick, partially peel up the top of the back rubber grip.
Carefully begin lifting the back cover up away from the camera body.
Use a plastic spudger to gently pry off the ribbon cable.
Use a plastic spudger to gently pry off the other cable connecting the back cover to the camera.
