跳转到主内容
Canon PowerShot SX160 IS LCD Replacement
Jamie Secretan
Jamie Secretan 另一个贡献者
最后更新于 June 22, 2015
15 - 30 分钟
中等
详尽分析
This guide walks you through how to replace a broken LCD screen on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
你所需要的
工具
  1. Canon PowerShot SX160 IS LCD Replacement, LCD: 步骤 1 中的图像 1,3 Canon PowerShot SX160 IS LCD Replacement, LCD: 步骤 1 中的图像 2,3 Canon PowerShot SX160 IS LCD Replacement, LCD: 步骤 1 中的图像 3,3
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD Replacement: 步骤 2 中的图像 1,2 Canon PowerShot SX160 IS LCD Replacement: 步骤 2 中的图像 2,2
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD Replacement: 步骤 3 中的图像 1,2 Canon PowerShot SX160 IS LCD Replacement: 步骤 3 中的图像 2,2
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD Replacement: 步骤 4 中的图像 1,1
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD Replacement: 步骤 5 中的图像 1,1
    • Using your hand, pull the LCD screen away from the camera and replace.
结论
Congratulations, you have successfully replaced your LCD screen. To reassemble your device, follow these instructions in reverse order.
2等其他人完成本指南。
Jamie Secretan
于03/11/15注册
1,990 声望
创作了6篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 1,534
