跳转到主内容
Canon PowerShot SX160 IS Clock Battery Replacement
Jamie Secretan
Jamie Secretan4 其他贡献者
最后更新于 April 8, 2024
15 - 30 分钟
中等
This guide walks you through how to replace the internal CR1220 battery on your Canon PowerShot SX160 IS by removing the battery tray on your camera.
你所需要的
配件
工具
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Canon PowerShot SX160 IS Clock Battery Replacement, Clock Battery: 步骤 1 中的图像 1,1
    • Locate the internal battery tray on the side of your camera.
    Thank you so much for your help. I was able to fix it without any problems.
    Barbara - 回复
    Your instructions to replace the battery was most helpful. Thank you.
    Barbara - 回复
  2. Canon PowerShot SX160 IS Clock Battery Replacement: 步骤 2 中的图像 1,1
    • Use your finger or a spudger to gently pry the battery tray out of the camera.
  3. Canon PowerShot SX160 IS Clock Battery Replacement: 步骤 3 中的图像 1,1
    • Fully remove the battery tray from the camera.
  4. Canon PowerShot SX160 IS Clock Battery Replacement: 步骤 4 中的图像 1,1
    • Remove battery from tray and replace.
    These photos show the battery upside-down. The positive goes down, towards the plastic tray, while the negative goes up, towards the open top of the tray.
    tomcatanzaro - 回复
    Thanks, Tom! I first put the battery in the way the photo displayed, and then set the date. When I turned the camera off, then on again, I got the message the date and time needed to be set. Changing to your way solved my problem! Thanks so much!!
    William Burke -
    Where can I buy batteries like these? Thanks
    Nicole - 回复
    Need a new battery tray…. Is there a way to get this part.
    Judy Bogner - 回复
结论
Congratulations, you have successfully replaced the internal battery. To reassemble your device, follow these instructions in reverse order.
37等其他人完成本指南。
Jamie Secretan
于03/11/15注册
1,990 声望
创作了6篇指南
团队
17条评论
Clear and simple. Thanks!
Jim - 回复
I had no idea! Thanks!
natorbett - 回复
Its not necessary to unscrew the tray.
Afzal Pawaskar - 回复
Thank you, Jamie!
Casey Cain - 回复
Gee I thought I am so glad I checked the Internet first...(before I threw it in the trash) that is how frustrating this was. Thank you everyone, I do love this camera
Barbara Rivers - 回复
thank you, i couldn't find it in the manual
ramar - 回复
Best camera I've ever had yet. All I have to do now is find a supplier for the battery.
carverdoone - 回复
My sentiments exactly like Barb Rivers. It's great to have someone like you guys do such a pro. job.
Many thanks and keep up the good work.
Richard Lange - 回复
Where do I go to buy this battery?
Louise Gladkowski - 回复
Love the canon camera I have this one, but it drains batteries when taking pictures? I have to bring a 8 pack of batteries it’s crazy!
Bonnie Bennett - 回复
I have a canon camera love it but it drains batteries have to bring a 8 pack something not right? Please let me know if it’s fixable or get a different one? Thanks
Bonnie Bennett - 回复
Tried for 2 days to get in touch with Canon with no response, Jaime solved it in seconds !
Drew - 回复
The pictures are wrong, the (+) and (-) are switched. Read the battery holder, that’s ok. Eze
adreze - 回复
i put new batterry to take shot still it showing low battery what will be the problem
montu bhagat - 回复
hi. direction easy, but still have problem
Suzanne LaCroix - 回复
got the battery out ok. now where the !&&* do i get a new one? no one carries it around my neck of the woods….
suesan629 - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 47
过去 30 天: 184
总计 50,531
