跳转到主内容
Canon PowerShot SD30 Screen Replacement
Erin Brophy
Erin Brophy5 其他贡献者
最后更新于 February 18, 2025
20 - 35 分钟
中等
更好的介绍
正在学习的学生
Is your camera not displaying your photos correctly or is the screen not showing any images? Consider using this guide to replace the screen of your camera.
你所需要的
工具
  1. Canon PowerShot SD30 Screen Replacement, Front Cover: 步骤 1 中的图像 1,2 Canon PowerShot SD30 Screen Replacement, Front Cover: 步骤 1 中的图像 2,2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Screen Replacement: 步骤 2 中的图像 1,1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 1,3 Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 2,3 Canon PowerShot SD30 Screen Replacement, Back Cover: 步骤 3 中的图像 3,3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Screen Replacement: 步骤 4 中的图像 1,1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Screen Replacement, Screen: 步骤 5 中的图像 1,2 Canon PowerShot SD30 Screen Replacement, Screen: 步骤 5 中的图像 2,2
    • Remove top button panel by removing the screw located at the top right of the panel.
  6. Canon PowerShot SD30 Screen Replacement: 步骤 6 中的图像 1,2 Canon PowerShot SD30 Screen Replacement: 步骤 6 中的图像 2,2
    • Remove screws both at the top and the base of the screen to free the screen.
  7. Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 1,3 Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 2,3 Canon PowerShot SD30 Screen Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    • Use tweezers to lift the tab that secures the screen wire and remove.
    • You need to do this for both wires.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 183
