跳转到主内容
Canon PowerShot SD1400 IS Battery Replacement
Matt Holquist
Matt Holquist2 其他贡献者
最后更新于 May 7, 2018
30秒 - 2分钟
简单
The battery for this camera may die when used frequently. This guide explains how to replace the battery.
  1. Canon PowerShot SD1400 IS Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • The battery compartment is located on the bottom of the camera, below the user interface panel.
  2. Canon PowerShot SD1400 IS Battery Replacement: 步骤 2 中的图像 1,1
    • The hatch covering the memory card will slide open towards the corner of the device.
  3. Canon PowerShot SD1400 IS Battery Replacement: 步骤 3 中的图像 1,1
    • Once the hatch is slid so the end is overhanging the edge of the camera, you will be able to lift it open.
  4. Canon PowerShot SD1400 IS Battery Replacement: 步骤 4 中的图像 1,1
    • Once open, you will see a small orange tab near the corner of the camera.
    • Push this tab towards the front face of the device, and the battery will freely fall out from the hatch.
结论
3等其他人完成本指南。
Matt Holquist
于02/01/18注册
157 声望
撰写一个指南
团队
Baylor, Team S1-G3, Johnson Spring 2018 Baylor, Team S1-G3, Johnson Spring 2018 的会员
BU-JOHNSON-S18S1G3
3 名成员
创作了4篇指南
1指南评论
Where do I go to pay?
drdenny46 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 54
总计 1,745
