跳转到主内容
Canon PowerShot G1 X View Finder Zoom Replacement
Joseph Cosgrove
Joseph Cosgrove6 其他贡献者
最后更新于 June 22, 2022
10 - 20 分钟
中等
动态照片拍摄
效率不高但可能有用的步骤
If the viewfinder wheel on your Canon PowerShot G1 X is broken, use this guide to replace the viewfinder wheel.
The viewfinder wheel is used to adjust the zoom level of the viewfinder. Depending on what part of the wheel is broken the wheel can either spin freely without changing the zoom or not move at all.
Before using this guide, check if debris is preventing the viewfinder zoom wheel from spinning. Use a toothpick or a Q-tip to remove the debris. If the debris cannot be removed follow this guide to remove the viewfinder zoom wheel and clear all the debris.
Make sure to power off your camera completely and disconnect from power before starting this guide.
你所需要的
工具
  • Spudger
    Spudger
  • Phillips #000 Screwdriver
查看更多...
  1. Canon PowerShot G1 X View Finder Zoom Replacement, Back Camera Casing: 步骤 1 中的图像 1,2 Canon PowerShot G1 X View Finder Zoom Replacement, Back Camera Casing: 步骤 1 中的图像 2,2
    • To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
    • Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
  2. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 2 中的图像 1,1
    • After removing the first screw flip to the bottom side of the camera and unscrew the two screws located toward the back side of the casing. The screw on the front side can be left in. Use a Phillips Head 00 screwdriver for both of these screws.
  3. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 3 中的图像 1,1
    • Now flip to the opposite side of the USB panel screw and unscrew the two screws holding the small speaker cover portion of the camera. Use a Phillips Head 00 screwdriver for both of these screws.
  4. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 4 中的图像 1,1
    • The last screw is located towards the top side of the back of the camera next to the view finder. Unscrew by using a Phillips Head 00 screwdriver.
  5. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 5 中的图像 1,1
    • Remove the side panel covering the speaker by gently pulling it away from the camera. You can also use spudgers to create a lever to help remove the panel.
  6. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 6 中的图像 1,1
    • Remove the back casing by gently pulling. You could also use spudger to create a lever to help pry it off.
  7. Canon PowerShot G1 X View Finder Zoom Replacement, View Finder Zoom: 步骤 7 中的图像 1,2 Canon PowerShot G1 X View Finder Zoom Replacement, View Finder Zoom: 步骤 7 中的图像 2,2
    • Locate the view finder zoom on the back of the camera.
    • Remove the screw using a Phillips #000 screwdriver.
    • Be careful, the viewfinder zoom wheel can fall if the camera is oriented vertically.
    • To remove the viewfinder wheel, pull it to the left and away from the camera.
  8. Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 8 中的图像 1,2 Canon PowerShot G1 X View Finder Zoom Replacement: 步骤 8 中的图像 2,2
    • Locate the viewfinder zoom pin seen in the first image.
    • Orient the viewfinder zoom pin to the same orientation as in the first image.
    • When reinstalling the viewfinder wheel, orient the notch in the viewfinder zoom wheel seen in the second image with the pin seen in the first image.
    • This will allow for the full range of motion of the viewfinder zoom wheel. Improper orientation will lead to a lower range of motion which can cause damage to the viewfinder.
结论
另外一个人完成了本指南。
Joseph Cosgrove
于02/12/17注册
313 声望
创作了3篇指南
团队
USF Tampa, Team 20-1, Remmell Spring 2017 USF Tampa, Team 20-1, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G1
3 名成员
创作了4篇指南
1指南评论
Do you guys know where I could get the aperture len flex for this model? Thank you!
Gissela Perdomo - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 945
