跳转到主内容
Canon PowerShot A620 Camera Housing Replacement
Jaime Abraham
Jaime Abraham4 其他贡献者
最后更新于 March 20, 2020
15 - 30 分钟
中等
需要更好的图片
更好的介绍
你所需要的
工具
  1. Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 步骤 1 中的图像 1,3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 步骤 1 中的图像 2,3 Canon PowerShot A620 Camera Housing Replacement, Open Battery Door: 步骤 1 中的图像 3,3
    • Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
  2. Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: 步骤 2 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Insert Batteries: 步骤 2 中的图像 2,2
    • Insert AA batteries according to the diagram printed on the camera.
    • Close the battery door.
  3. Canon PowerShot A620 Camera Housing Replacement, Side Panel: 步骤 3 中的图像 1,3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: 步骤 3 中的图像 2,3 Canon PowerShot A620 Camera Housing Replacement, Side Panel: 步骤 3 中的图像 3,3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  4. Canon PowerShot A620 Camera Housing Replacement, Bottom Panel: 步骤 4 中的图像 1,1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  5. Canon PowerShot A620 Camera Housing Replacement, Battery Compartment: 步骤 5 中的图像 1,1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  6. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 步骤 6 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 步骤 6 中的图像 2,2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  7. Canon PowerShot A620 Camera Housing Replacement, Top Panel: 步骤 7 中的图像 1,1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  8. Canon PowerShot A620 Camera Housing Replacement, Front Panel: 步骤 8 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Front Panel: 步骤 8 中的图像 2,2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  9. Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 步骤 9 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Terminal Cover: 步骤 9 中的图像 2,2
    • Gently pull the terminal cover to separate it from the camera.
  10. Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: 步骤 10 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Memory Card Cover: 步骤 10 中的图像 2,2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  11. Canon PowerShot A620 Camera Housing Replacement, Back Panel: 步骤 11 中的图像 1,2 Canon PowerShot A620 Camera Housing Replacement, Back Panel: 步骤 11 中的图像 2,2
    • Gently pull the back panel to separate it from the camera.
结论
2等其他人完成本指南。
Jaime Abraham
于09/08/14注册
350 声望
创作了3篇指南
团队
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 的会员
CSUF-BRUCE-F14S1G1
3 名成员
创作了6篇指南
一条评论
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
Paolo Ravera - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 44
总计 1,799
