跳转到主内容
加入维修社区 - 创建账户
Canon PowerShot A590 IS Batteries Replacement
你所需要的
  1. Canon PowerShot A590 IS Batteries Replacement, Batteries: 步骤 1 中的图像 1,2 Canon PowerShot A590 IS Batteries Replacement, Batteries: 步骤 1 中的图像 2,2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Batteries Replacement: 步骤 2 中的图像 1,1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
    询问修复机器人
  3. Canon PowerShot A590 IS Batteries Replacement: 步骤 3 中的图像 1,1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
    询问修复机器人
结论
2等其他人完成本指南。
Zach
于10/11/10注册
284 声望
创作了6篇指南
团队
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 的会员
CPSU-REGAN-F10S9G19
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 63
总计 8,391
