跳转到主内容
Canon PowerShot A540 SD Card Reader Replacement
Cooper Hale
Cooper Hale3 其他贡献者
最后更新于 May 7, 2024
15 - 20 分钟
中等
If your camera keeps showing you an "SD card error"message, but the SD card in use is the correct type and is uncorrupted, your SD card reader may be in need of replacement. After removing the back cover and the LCD screen, you will be able to replace the SD card reader yourself.
你所需要的
工具
查看更多...
  1. Canon PowerShot A540 SD Card Reader Replacement, Back Cover: 步骤 1 中的图像 1,2 Canon PowerShot A540 SD Card Reader Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn off the camera.
    • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
  2. Canon PowerShot A540 SD Card Reader Replacement: 步骤 2 中的图像 1,1
    • Turn the camera upside down to view the "Card/Batt. Open" Cover.
    • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
  3. Canon PowerShot A540 SD Card Reader Replacement: 步骤 3 中的图像 1,1
    • Open "Card/Batt. Open" Cover.
    • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
  4. Canon PowerShot A540 SD Card Reader Replacement: 步骤 4 中的图像 1,1
    • Turn the camera to the right side of the LCD screen.
    • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
  5. Canon PowerShot A540 SD Card Reader Replacement: 步骤 5 中的图像 1,3 Canon PowerShot A540 SD Card Reader Replacement: 步骤 5 中的图像 2,3 Canon PowerShot A540 SD Card Reader Replacement: 步骤 5 中的图像 3,3
    • Gently remove the back cover.
    • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
    • Then move onto the other edges and the top.
    • It may be tight at the top!
  6. Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: 步骤 6 中的图像 1,2 Canon PowerShot A540 SD Card Reader Replacement, SD Card Reader: 步骤 6 中的图像 2,2
    • Turn the camera to view the back.
    • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
    • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
  7. Canon PowerShot A540 SD Card Reader Replacement: 步骤 7 中的图像 1,2 Canon PowerShot A540 SD Card Reader Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Lift the LCD Screen off of the back to view the attached ribbon cables.
    • Use tweezers to flip the black bar up.
  8. Canon PowerShot A540 SD Card Reader Replacement: 步骤 8 中的图像 1,3 Canon PowerShot A540 SD Card Reader Replacement: 步骤 8 中的图像 2,3 Canon PowerShot A540 SD Card Reader Replacement: 步骤 8 中的图像 3,3
    • Gently pull the big ribbon out.
    • Gently pull the small ribbon out.
    • The small ribbon does not have a bar like the big ribbon.
  9. Canon PowerShot A540 SD Card Reader Replacement: 步骤 9 中的图像 1,2 Canon PowerShot A540 SD Card Reader Replacement: 步骤 9 中的图像 2,2
    • Remove the two (2) 3.0 mm screws shown with the Phillips head #000 screwdriver.
  10. Canon PowerShot A540 SD Card Reader Replacement: 步骤 10 中的图像 1,2 Canon PowerShot A540 SD Card Reader Replacement: 步骤 10 中的图像 2,2
    • Remove the ribbon from the clamp/bar securing it by using your tweezers to pull the bar up.
  11. Canon PowerShot A540 SD Card Reader Replacement: 步骤 11 中的图像 1,1
    • Remove the SD Card reader and replace.
    • There is another metal bar that comes off of the SD Card reader when screws are removed.
结论
2等其他人完成本指南。
Cooper Hale
于03/22/15注册
598 声望
创作了3篇指南
团队
Baylor, Team 7-12, Williams Spring 2015 Baylor, Team 7-12, Williams Spring 2015 的会员
BU-WILLIAMS-S15S7G12
3 名成员
创作了20篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 25
总计 1,380
