跳转到主内容
Canon EOS Rebel XS Strap Loops Replacement
Daniel Bussone
Daniel Bussone6 其他贡献者
最后更新于 October 22, 2024
没有估计
中等
Use this guide to remove the two metal neck strap loops.
你所需要的
工具
查看更多...
  1. Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: 步骤 1 中的图像 1,2 Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: 步骤 1 中的图像 2,2
    • Grasp the eyepiece with your fingers and slide upwards to remove it.
  2. Canon EOS Rebel XS Strap Loops Replacement, Top Cover: 步骤 2 中的图像 1,2 Canon EOS Rebel XS Strap Loops Replacement, Top Cover: 步骤 2 中的图像 2,2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  3. Canon EOS Rebel XS Strap Loops Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  4. Canon EOS Rebel XS Strap Loops Replacement: 步骤 4 中的图像 1,1
    • Pull off the front cover.
  5. Canon EOS Rebel XS Strap Loops Replacement: 步骤 5 中的图像 1,3 Canon EOS Rebel XS Strap Loops Replacement: 步骤 5 中的图像 2,3 Canon EOS Rebel XS Strap Loops Replacement: 步骤 5 中的图像 3,3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  6. Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: 步骤 6 中的图像 1,3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: 步骤 6 中的图像 2,3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: 步骤 6 中的图像 3,3
    • Remove the two 5.0mm (.20in) silver screws from the first loop hole using a #00 Phillips screwdriver (Picture Two).
    • Remove the 6.8mm (.27in) wide head silver screw from the second loop hole using a #00 Phillips screwdriver (Picture Three).
  7. Canon EOS Rebel XS Strap Loops Replacement: 步骤 7 中的图像 1,2 Canon EOS Rebel XS Strap Loops Replacement: 步骤 7 中的图像 2,2
    • Use your fingers to remove the loop holes.
结论
Daniel Bussone
于01/28/11注册
1,260 声望
创作了11篇指南
团队
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G41
2 名成员
创作了21篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 964
