跳转到主内容
Canon EOS Rebel T5 Back Cover Removal
Johnyp
Johnyp5 其他贡献者
最后更新于 January 3, 2025
15分钟
中等
If you are going to replace any of the major components of your camera, you will need to first remove the back cover. This guide will teach you how to open up your camera.
你所需要的
  1. Canon EOS Rebel T5 Back Cover Removal, Battery: 步骤 1 中的图像 1,1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Cover Removal: 步骤 2 中的图像 1,1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Cover Removal, Back Cover: 步骤 3 中的图像 1,1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Cover Removal: 步骤 4 中的图像 1,1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Cover Removal: 步骤 5 中的图像 1,1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm JIS #000 screws.
  6. Canon EOS Rebel T5 Back Cover Removal: 步骤 6 中的图像 1,1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
  7. Canon EOS Rebel T5 Back Cover Removal: 步骤 7 中的图像 1,3 Canon EOS Rebel T5 Back Cover Removal: 步骤 7 中的图像 2,3 Canon EOS Rebel T5 Back Cover Removal: 步骤 7 中的图像 3,3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
结论
5等其他人完成本指南。
Johnyp
于08/26/15注册
266 声望
撰写一个指南
团队
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G4
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 3,661
