跳转到主内容
Canon EOS 60D Rear LCD Screen Removal
Tyler Vaal
Tyler Vaal6 其他贡献者
最后更新于 May 7, 2024
没有估计
简单
If you drop your camera and crack or damage your screen, this guide will help you replace it.
When performing this replacement please remember that the screws you will be removing are very small. Keep them organized as you take them off and find a magnetic holder to put them in. Good luck!
你所需要的
工具
查看更多...
  1. Canon EOS 60D Rear LCD Screen Removal, Rear LCD Screen Dissasembly: 步骤 1 中的图像 1,1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Removal: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Removal: 步骤 3 中的图像 1,2 Canon EOS 60D Rear LCD Screen Removal: 步骤 3 中的图像 2,2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Removal: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
结论
2等其他人完成本指南。
Tyler Vaal
于08/30/15注册
695 声望
创作了3篇指南
团队
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 的会员
USFT-WOLLERT-F15S16G6
3 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 23
总计 1,421
