跳转到主内容
Canon EOS 60D Left-Side Port Cover Replacement
Eric D
Eric D2 其他贡献者
最后更新于 February 1, 2020
5 - 10 分钟
简单
社区贡献指南
This will allow you access to the ports, or if you need to replace the dust cover, will allow you to do that.
你所需要的
工具
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
查看更多...
  1. Canon EOS 60D Left-Side Port Cover Replacement, Rubber grips: 步骤 1 中的图像 1,1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  2. Canon EOS 60D Left-Side Port Cover Replacement, Left-Side Port Cover: 步骤 2 中的图像 1,1
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  3. Canon EOS 60D Left-Side Port Cover Replacement: 步骤 4 中的图像 1,1
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  4. Canon EOS 60D Left-Side Port Cover Replacement: 步骤 5 中的图像 1,1
    • Slide the rear part of the cover out.
  5. Canon EOS 60D Left-Side Port Cover Replacement: 步骤 6 中的图像 1,2 Canon EOS 60D Left-Side Port Cover Replacement: 步骤 6 中的图像 2,2
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
结论
8等其他人完成本指南。
Eric D
于11/13/12注册
1,362 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 45
总计 7,488
