跳转到主内容
Canon EOS 40D Flash Hot Shoe Replacement
Sarah de Freitas
Sarah de Freitas3 其他贡献者
最后更新于 January 26, 2020
5 - 10 分钟
简单
If the flash does not fire after you have cleaned the hotshoe of your Canon EOS 40D or after you have attempted to lift the flash switch by passing a toothpick under the right side of the hotshoe, you may need to replace the entire hot shoe. Follow this guide to replace the flash hot shoe that matches Canon EOS 40D.
你所需要的
工具
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: 步骤 1 中的图像 1,1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Flash Hot Shoe Replacement: 步骤 2 中的图像 1,1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Flash Hot Shoe Replacement: 步骤 3 中的图像 1,1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: 步骤 4 中的图像 1,3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: 步骤 4 中的图像 2,3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: 步骤 4 中的图像 3,3
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
  5. Canon EOS 40D Flash Hot Shoe Replacement: 步骤 5 中的图像 1,3 Canon EOS 40D Flash Hot Shoe Replacement: 步骤 5 中的图像 2,3 Canon EOS 40D Flash Hot Shoe Replacement: 步骤 5 中的图像 3,3
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
结论
4等其他人完成本指南。
团队
USF Tampa, Team 12-3, Blackwell Fall 2015 USF Tampa, Team 12-3, Blackwell Fall 2015 的会员
USFT-BLACKWELL-F15S12G3
4 名成员
创作了16篇指南
1指南评论
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 68
总计 4,819
