跳转到主内容
CHUWI GemiBook XPro Battery Replacement
JakeV
JakeV4 其他贡献者
最后更新于 December 18, 2024
10 - 15 分钟
中等
特色学生指南
You may find it necessary to replace the battery on the CHUWI GemiBook XPro due to its charging rate or capacity. This easy-to-follow guide will assist in the process of battery removal and replacement. For this guide you’ll need a philips #1 screwdriver, the spudger, and opening picks in order to disassemble and replace the battery in an orderly fashion.
你所需要的
配件
工具
查看更多...
  1. CHUWI GemiBook XPro Battery Replacement, Lower Case: 步骤 1 中的图像 1,2 CHUWI GemiBook XPro Battery Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Discharge the battery below 25%, since a charged lithium-ion battery is a potential safety hazard. Fully power down the laptop and unplug any peripheries.
    • Orient the device to where you can see the bottom of the case.
    • Use a Phillips #1 screwdriver to remove the twelve 5.6 mm screws that secure the lower case.
  2. CHUWI GemiBook XPro Battery Replacement: 步骤 2 中的图像 1,3 CHUWI GemiBook XPro Battery Replacement: 步骤 2 中的图像 2,3 CHUWI GemiBook XPro Battery Replacement: 步骤 2 中的图像 3,3
    • Insert an opening pick into the gap between the lower case and the chassis.
    • Pry along the entire perimeter of the laptop until the lower case fully releases.
    • Lift the lower case up and off of the chassis.
  3. CHUWI GemiBook XPro Battery Replacement, Battery: 步骤 3 中的图像 1,2 CHUWI GemiBook XPro Battery Replacement, Battery: 步骤 3 中的图像 2,2
    • Peel off the black tape on the upper-right side of the motherboard.
  4. CHUWI GemiBook XPro Battery Replacement: 步骤 4 中的图像 1,2 CHUWI GemiBook XPro Battery Replacement: 步骤 4 中的图像 2,2
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  5. CHUWI GemiBook XPro Battery Replacement: 步骤 5 中的图像 1,3 CHUWI GemiBook XPro Battery Replacement: 步骤 5 中的图像 2,3 CHUWI GemiBook XPro Battery Replacement: 步骤 5 中的图像 3,3
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  6. CHUWI GemiBook XPro Battery Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  7. CHUWI GemiBook XPro Battery Replacement: 步骤 7 中的图像 1,3 CHUWI GemiBook XPro Battery Replacement: 步骤 7 中的图像 2,3 CHUWI GemiBook XPro Battery Replacement: 步骤 7 中的图像 3,3
    • Lift the battery up and out of the chassis.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
JakeV
于08/28/24注册
407 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 70
总计 264
