跳转到主内容
Brother CS6000i Sewing Needle Replacement
Gavin Vella
Gavin Vella2 其他贡献者
最后更新于 December 31, 2024
2分钟
简单
This guide teaches the user how to remove and replace the sewing needle for the Brother CS6000i. The needle is responsible for stitching threads into whatever material the user works on.
A replacement for the sewing needle is needed in the case where it is either stuck, dulled, or bent. Be careful not to bend it during the replacement process. To ensure the needle doesn't fall during screwing and unscrewing, hold it with one hand until it is finally released.
  1. Brother CS6000i Sewing Needle Replacement, Sewing Needle: 步骤 1 中的图像 1,2 Brother CS6000i Sewing Needle Replacement, Sewing Needle: 步骤 1 中的图像 2,2
    • Unscrew the needle clamp located above and to the right of the sewing needle.
    • Remove the needle by pulling down at the base.
结论
To input a new sewing needle, follow these instructions in reverse order.
Gavin Vella
于10/24/24注册
73 声望
撰写一个指南
团队
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024 的会员
CUESTA-KRYNEN-F24S20G1
5 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 60
