跳转到主内容
加入维修社区 - 创建账户
Blackberry PRIV Battery Replacement
你所需要的
    1. Blackberry PRIV Battery Replacement, Rear Casing: 步骤 1 中的图像 1,3 Blackberry PRIV Battery Replacement, Rear Casing: 步骤 1 中的图像 2,3 Blackberry PRIV Battery Replacement, Rear Casing: 步骤 1 中的图像 3,3
      • Look for the two small holes at the top of your device.
      • Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
      • Pull the trays up and out of the device.
      询问修复机器人
      添加评论
    2. Blackberry PRIV Battery Replacement: 步骤 2 中的图像 1,3 Blackberry PRIV Battery Replacement: 步骤 2 中的图像 2,3 Blackberry PRIV Battery Replacement: 步骤 2 中的图像 3,3
      • Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
      • Follow this procedure for only the right, left, and top side of the casing.
      询问修复机器人
      添加评论
    3. Blackberry PRIV Battery Replacement: 步骤 3 中的图像 1,3 Blackberry PRIV Battery Replacement: 步骤 3 中的图像 2,3 Blackberry PRIV Battery Replacement: 步骤 3 中的图像 3,3
      • Remove the rear casing by sliding the case down and out.
      询问修复机器人
      添加评论
    1. Blackberry PRIV Battery Replacement, Battery: 步骤 4 中的图像 1,2 Blackberry PRIV Battery Replacement, Battery: 步骤 4 中的图像 2,2
      • Remove the two 3.3 mm T4 Torx screws that secure the battery connector.
      • There may be a plastic protector covering the circuit board and battery. Remove the plastic protector to begin.
      询问修复机器人
      添加评论
    2. Blackberry PRIV Battery Replacement: 步骤 5 中的图像 1,2 Blackberry PRIV Battery Replacement: 步骤 5 中的图像 2,2
      • Use an opening tool to lift and disconnect the battery connector.
      询问修复机器人
      添加评论
    3. Blackberry PRIV Battery Replacement: 步骤 6 中的图像 1,3 Blackberry PRIV Battery Replacement: 步骤 6 中的图像 2,3 Blackberry PRIV Battery Replacement: 步骤 6 中的图像 3,3
      • Pull on the plastic tab to remove the battery from the device.
      • For easier removal, use a blow dryer to warm the battery glue.
      • Be careful to not overheat the battery or puncture the battery as lithium batteries are dangerous.
      询问修复机器人
      添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 27
过去 30 天: 87
总计 1,042
