跳转到主内容
加入维修社区 - 创建账户
Battery Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnection, Prepare your phone for disassembly: 步骤 1 中的图像 1,2 Battery Disconnection, Prepare your phone for disassembly: 步骤 1 中的图像 2,2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard. If your battery is swollen, take appropriate precautions.
    • Unplug any cables from your phone.
    • Hold the side key and the volume down button, then select "Power off" to turn off your phone.
  2. Battery Disconnection, Heat the right edge: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You may use a hair dryer, heat gun, or hot plate instead, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Battery Disconnection, Insert an opening pick: 步骤 3 中的图像 1,3 Battery Disconnection, Insert an opening pick: 步骤 3 中的图像 2,3 Battery Disconnection, Insert an opening pick: 步骤 3 中的图像 3,3
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  4. Battery Disconnection, Separate the right adhesive: 步骤 4 中的图像 1,3 Battery Disconnection, Separate the right adhesive: 步骤 4 中的图像 2,3 Battery Disconnection, Separate the right adhesive: 步骤 4 中的图像 3,3
    • Slide the pick back and forth along the right edge to separate the adhesive.
    • Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
  5. Battery Disconnection, Heat the bottom edge: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the bottom edge of the back cover for two minutes.
  6. Battery Disconnection, Separate the bottom adhesive: 步骤 6 中的图像 1,3 Battery Disconnection, Separate the bottom adhesive: 步骤 6 中的图像 2,3 Battery Disconnection, Separate the bottom adhesive: 步骤 6 中的图像 3,3
    • Insert a second opening pick next to the first one, near the bottom of the right edge.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Battery Disconnection: 步骤 7 中的图像 1,2 Battery Disconnection: 步骤 7 中的图像 2,2
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the pick inserted near the bottom left corner to prevent the adhesive from resealing.
  8. Battery Disconnection, Heat the left edge: 步骤 8 中的图像 1,1
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  9. Battery Disconnection, Separate the left adhesive: 步骤 9 中的图像 1,3 Battery Disconnection, Separate the left adhesive: 步骤 9 中的图像 2,3 Battery Disconnection, Separate the left adhesive: 步骤 9 中的图像 3,3
    • Insert a third opening pick next to the second one, near the left side of the bottom edge.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Battery Disconnection: 步骤 10 中的图像 1,2 Battery Disconnection: 步骤 10 中的图像 2,2
    • Slide your opening pick along the left edge to separate the adhesive, stopping before you reach the power button.
    • Do not insert the pick more than 4 mm to avoid damaging the antenna cable.
    • Leave the pick inserted near the power button to prevent the adhesive from resealing.
  11. Battery Disconnection, Heat the top edge: 步骤 11 中的图像 1,1
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Battery Disconnection, Separate the top adhesive: 步骤 12 中的图像 1,3 Battery Disconnection, Separate the top adhesive: 步骤 12 中的图像 2,3 Battery Disconnection, Separate the top adhesive: 步骤 12 中的图像 3,3
    • Insert an opening pick in the gap at the top of the right edge.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  13. Battery Disconnection: 步骤 13 中的图像 1,2 Battery Disconnection: 步骤 13 中的图像 2,2
    • Slide the pick along the top edge to separate the adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the sensor or camera near the top edge.
  14. Battery Disconnection, Separate the remaining adhesive: 步骤 14 中的图像 1,3 Battery Disconnection, Separate the remaining adhesive: 步骤 14 中的图像 2,3 Battery Disconnection, Separate the remaining adhesive: 步骤 14 中的图像 3,3
    • Slide the pick around the top left corner and down the left edge to separate the remaining adhesive.
    • Do not insert the pick more than 4 mm to avoid damaging the cameras.
  15. Battery Disconnection, Remove the back cover: 步骤 15 中的图像 1,2 Battery Disconnection, Remove the back cover: 步骤 15 中的图像 2,2
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the edges to separate any adhesive that may have resealed.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Battery Disconnection, Disconnect the wireless charging coil: 步骤 16 中的图像 1,2 Battery Disconnection, Disconnect the wireless charging coil: 步骤 16 中的图像 2,2
    • Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • There's an arrow printed on the board near each press connector that indicates the recommended prying location. Only pry in this location for each press connector to avoid dislodging surface-mounted components.
    • To reconnect press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Battery Disconnection, Remove the wireless charging coil and loudspeaker screws: 步骤 17 中的图像 1,2 Battery Disconnection, Remove the wireless charging coil and loudspeaker screws: 步骤 17 中的图像 2,2
    • Use a Phillips screwdriver to remove the ten 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Four screws securing the wireless charging coil
    • Six screws securing the loudspeaker
  18. Battery Disconnection, Separate the coil adhesive: 步骤 18 中的图像 1,2 Battery Disconnection, Separate the coil adhesive: 步骤 18 中的图像 2,2
    • Use a spudger to gently pry up a corner of the tab of the wireless charging coil that's adhered to the right edge of the frame.
  19. Battery Disconnection: 步骤 19 中的图像 1,2 Battery Disconnection: 步骤 19 中的图像 2,2
    • Use an opening pick to separate the tab from the frame.
  20. Battery Disconnection, Remove the wireless charging coil and loudspeaker: 步骤 20 中的图像 1,2 Battery Disconnection, Remove the wireless charging coil and loudspeaker: 步骤 20 中的图像 2,2
    • Insert the point of a spudger into the gap between the right edge of the loudspeaker and the frame.
    • There's an arrow engraved in the loudspeaker to indicate the recommended prying location.
    • Pry up to unclip the loudspeaker from the frame.
  21. Battery Disconnection: 步骤 21 中的图像 1,2 Battery Disconnection: 步骤 21 中的图像 2,2
    • Remove the wireless charging coil and loudspeaker from the frame.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  22. Battery Disconnection, Disconnect the battery: 步骤 22 中的图像 1,2 Battery Disconnection, Disconnect the battery: 步骤 22 中的图像 2,2
    • Use a spudger to pry up and disconnect the battery press connector.
结论
Spencer Pennington
于09/09/23注册
23,963 声望
创作了125篇指南
团队
Guide Team Guide Team 的会员
Staff
10 名成员
创作了16,061篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 55
