跳转到主内容
加入维修社区 - 创建账户
Battery Disconnect
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnect, Remove the SIM card tray: 步骤 1 中的图像 1,3 Battery Disconnect, Remove the SIM card tray: 步骤 1 中的图像 2,3 Battery Disconnect, Remove the SIM card tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, bit, or straightened paperclip into the SIM card tray hole on the left edge of the phone.
    • Push the SIM eject tool into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Battery Disconnect, Heat the right edge: 步骤 2 中的图像 1,1
    • Heat an iOpener and apply it to the back cover's right edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Battery Disconnect, Insert an opening pick: 步骤 3 中的图像 1,2 Battery Disconnect, Insert an opening pick: 步骤 3 中的图像 2,2
    • Flip your phone over so the display is facing up.
    • Apply a suction handle to the middle of the display's left edge, as close to the edge as possible.
    • Place the tip of an opening pick in the small gap between the back cover and the display.
    • Pull up on the suction cup with a strong, steady force and push the opening pick down at a 45 degree angle until it slides into the gap between the back cover and the display.
    • If you're having a hard time inserting the pick, reheat the adhesive with an iOpener and try again.
  4. Battery Disconnect, Slice the left adhesive: 步骤 4 中的图像 1,3 Battery Disconnect, Slice the left adhesive: 步骤 4 中的图像 2,3 Battery Disconnect, Slice the left adhesive: 步骤 4 中的图像 3,3
    • Both adhesive and clips secure the back cover.
    • During steps that involve sliding the opening pick, keep it angled down at a 45 degree angle.
    • Slide the pick along the left edge down to the bottom left corner, and then up to the top left corner, to release the clips and slice the adhesive.
    • Leave the pick inserted in the top left corner to prevent the adhesive from resealing.
  5. Battery Disconnect, Heat the top edge: 步骤 5 中的图像 1,1
    • Flip your phone over and apply a heated iOpener to the back cover's top edge for two minutes.
  6. Battery Disconnect: 步骤 6 中的图像 1,2 Battery Disconnect: 步骤 6 中的图像 2,2
    • Flip your phone over and rotate the pick around the top left corner.
  7. Battery Disconnect: 步骤 7 中的图像 1,2 Battery Disconnect: 步骤 7 中的图像 2,2
    • Slide the pick along the top edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the top right corner.
  8. Battery Disconnect: 步骤 8 中的图像 1,1
    • Flip your phone over and apply a heated iOpener to the back cover's left edge for two minutes.
  9. Battery Disconnect: 步骤 9 中的图像 1,2 Battery Disconnect: 步骤 9 中的图像 2,2
    • Flip your phone over and rotate the pick around the top right corner.
  10. Battery Disconnect: 步骤 10 中的图像 1,2 Battery Disconnect: 步骤 10 中的图像 2,2
    • Slide the pick along the right edge to release the clips and slice the adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from resealing.
  11. Battery Disconnect: 步骤 11 中的图像 1,1
    • Flip your phone over and apply a heated iOpener to the back cover's bottom edge for two minutes.
  12. Battery Disconnect: 步骤 12 中的图像 1,2 Battery Disconnect: 步骤 12 中的图像 2,2
    • Flip your phone over and rotate the pick around the bottom right corner.
  13. Battery Disconnect: 步骤 13 中的图像 1,2 Battery Disconnect: 步骤 13 中的图像 2,2
    • Slide the opening pick along the bottom edge to release the clips and slice the adhesive.
  14. Battery Disconnect: 步骤 14 中的图像 1,2 Battery Disconnect: 步骤 14 中的图像 2,2
    • Flip your phone over and apply a heated iOpener to the fingerprint sensor on the back cover for two minutes.
  15. Battery Disconnect, Detach the fingerprint sensor: 步骤 15 中的图像 1,3 Battery Disconnect, Detach the fingerprint sensor: 步骤 15 中的图像 2,3 Battery Disconnect, Detach the fingerprint sensor: 步骤 15 中的图像 3,3
    • Adhesive secures the fingerprint sensor to the back case.
    • A fragile cable secures the fingerprint sensor to the motherboard. Be very careful during this step to avoid damaging the cable.
    • Press down on the fingerprint sensor with the flat end of a spudger or your finger.
    • While pressing down on the fingerprint sensor, gently pull up the bottom edge of the back cover until the sensor detaches.
  16. Battery Disconnect, Remove the back cover: 步骤 16 中的图像 1,3 Battery Disconnect, Remove the back cover: 步骤 16 中的图像 2,3 Battery Disconnect, Remove the back cover: 步骤 16 中的图像 3,3
    • Lift the back cover up and remove it.
    • If the back cover is still stuck to the frame, slide an opening pick around the entire perimeter until the cover separates completely.
    • During reassembly:
    • This is a good point to test your phone's functionality before sealing it up. Use this guide to run a hardware test. Be sure to power your phone back down completely before you continue working.
    • Apply new adhesive to the perimeter of the underside of the back cover after cleaning the relevant areas with isopropyl alcohol (>90%) and a micro-fiber cloth.
  17. Battery Disconnect, Detach the fingerprint sensor: 步骤 17 中的图像 1,2 Battery Disconnect, Detach the fingerprint sensor: 步骤 17 中的图像 2,2
    • The fingerprint reader is secured to the motherboard cover with light adhesive.
    • Insert the flat end of a spudger under the fingerprint sensor.
    • Gently pry up and detach the fingerprint sensor from the motherboard cover.
    • Don't try to remove the fingerprint sensor yet, as it's still attached to the motherboard by a delicate ribbon cable.
  18. Battery Disconnect, Unfasten the motherboard cover: 步骤 18 中的图像 1,2 Battery Disconnect, Unfasten the motherboard cover: 步骤 18 中的图像 2,2
    • Use a Phillips screwdriver to remove the seven 3.9 mm screws securing the motherboard cover.
  19. Battery Disconnect, Unclip the motherboard cover: 步骤 19 中的图像 1,2 Battery Disconnect, Unclip the motherboard cover: 步骤 19 中的图像 2,2
    • The motherboard cover is secured with tight clips.
    • Insert the flat end of a spudger in the gap between the frame and the bottom left corner of the motherboard cover.
    • Lift straight up with the spudger to release the clips securing the motherboard.
    • Don't pry against the battery, as this could damage it.
    • This may take take a few attempts. It you're having trouble, try gripping the spudger closer to the flat end.
    • During reassembly, press down around the perimeter of the motherboard cover to engage the clips.
  20. Battery Disconnect, Remove the motherboard cover: 步骤 20 中的图像 1,2 Battery Disconnect, Remove the motherboard cover: 步骤 20 中的图像 2,2
    • Pull the motherboard cover towards the top of the phone to remove it.
    • Make sure to avoid the fingerprint sensor cable when removing the cover, as it can easily rip.
  21. Battery Disconnect, Disconnect the battery: 步骤 21 中的图像 1,2 Battery Disconnect, Disconnect the battery: 步骤 21 中的图像 2,2
    • Use the flat end of a spudger to pry up and disconnect the battery cable's press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
结论
Spencer Day
于09/14/22注册
160,273 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,996篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 76
