跳转到主内容
Basis B1 Band LED Screen Replacement
Kaitlyn Lee
Kaitlyn Lee 另一个贡献者
最后更新于 December 28, 2017
20 - 30 分钟
困难
动态照片拍摄
需要更好的图片
This guide shows how to replace the LED screen. This is a more complicated guide because it involves removing the back plate of the watch along with the battery.
你所需要的
工具
查看更多...
  1. Basis B1 Band LED Screen Replacement, Watch Strap: 步骤 1 中的图像 1,1
    • Wedge a plastic opening tool between band contacts.
  2. Basis B1 Band LED Screen Replacement: 步骤 2 中的图像 1,1
    • Push in plastic opening tool until the components click and pop out of the holder.
    • Repeat steps for other band.
  3. Basis B1 Band LED Screen Replacement, Back Plate: 步骤 3 中的图像 1,1
    • Remove four 4mm screws using a PH000 screwdriver.
    • Remove back plate.
  4. Basis B1 Band LED Screen Replacement, Battery: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to remove elastomeric, or zebra, connector.
  5. Basis B1 Band LED Screen Replacement: 步骤 5 中的图像 1,2 Basis B1 Band LED Screen Replacement: 步骤 5 中的图像 2,2
    • Use the flat end of the spudger to carefully lift the battery until adhesive seal is broken.
  6. Basis B1 Band LED Screen Replacement: 步骤 6 中的图像 1,1
    • Use the pointy edge of the spudger tool to detach battery leads from the circuit board.
  7. Basis B1 Band LED Screen Replacement, LED Screen: 步骤 7 中的图像 1,2 Basis B1 Band LED Screen Replacement, LED Screen: 步骤 7 中的图像 2,2
    • Use PH000 screw driver to remove two 6mm bracketed screws.
    • Remove bracket.
  8. Basis B1 Band LED Screen Replacement: 步骤 8 中的图像 1,1
    • Use PH000 tool to remove two 4mm screws.
  9. Basis B1 Band LED Screen Replacement: 步骤 9 中的图像 1,1
  10. Basis B1 Band LED Screen Replacement: 步骤 10 中的图像 1,1
    • Use spudger tool to lift the clasp of LED connector strip and remove from watch case.
  11. Basis B1 Band LED Screen Replacement: 步骤 11 中的图像 1,1
    • Use spudger tool to remove the LED screen from the watch case.
结论
Kaitlyn Lee
于11/06/17注册
518 声望
创作了4篇指南
团队
IUPUI, Team S6-G1, Baechle Fall 2017 IUPUI, Team S6-G1, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S6G1
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 235
