跳转到主内容
加入维修社区 - 创建账户
Asus ROG G20CB CPU Replacement
你所需要的
    1. Asus ROG G20CB CPU Replacement, Fan: 步骤 1 中的图像 1,2 Asus ROG G20CB CPU Replacement, Fan: 步骤 1 中的图像 2,2
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      询问修复机器人
      添加评论
    2. Asus ROG G20CB CPU Replacement: 步骤 2 中的图像 1,1
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      询问修复机器人
      添加评论
    3. Asus ROG G20CB CPU Replacement: 步骤 3 中的图像 1,1
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      询问修复机器人
      添加评论
    4. Asus ROG G20CB CPU Replacement: 步骤 4 中的图像 1,1
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      询问修复机器人
      添加评论
    5. Asus ROG G20CB CPU Replacement: 步骤 5 中的图像 1,1
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      询问修复机器人
      添加评论
    6. Asus ROG G20CB CPU Replacement: 步骤 6 中的图像 1,1
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      询问修复机器人
      添加评论
    1. Asus ROG G20CB CPU Replacement, CPU Cooler: 步骤 7 中的图像 1,1
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      询问修复机器人
      添加评论
    2. Asus ROG G20CB CPU Replacement: 步骤 8 中的图像 1,1
      • Push the optical drive out of the chassis.
      询问修复机器人
      添加评论
    3. Asus ROG G20CB CPU Replacement: 步骤 9 中的图像 1,1
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      询问修复机器人
      添加评论
    4. Asus ROG G20CB CPU Replacement: 步骤 10 中的图像 1,1
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      询问修复机器人
      添加评论
    1. Asus ROG G20CB CPU Replacement, CPU: 步骤 11 中的图像 1,1
      • Locate the CPU socket retention arm next to the processor.
      • Push the arm down and out, then lift it upward to release the CPU cover.
      询问修复机器人
      添加评论
    2. Asus ROG G20CB CPU Replacement: 步骤 12 中的图像 1,1
      • Gently lift the CPU straight out of the socket.
      • Handle the CPU by its edges. Do not touch the bottom pins or contacts to avoid damage.
      询问修复机器人
      添加评论
    3. Asus ROG G20CB CPU Replacement: 步骤 13 中的图像 1,1
      • Reassembly tip: When installing a new CPU make sure to align the gold triangle with the white circle on the motherboard.
      询问修复机器人
      添加评论
结论
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kimber-Starr
于03/21/25注册
361 声望
创作了3篇指南
团队
UMass Dartmouth, Team 3-3, Botvin Spring 2025 UMass Dartmouth, Team 3-3, Botvin Spring 2025 的会员
UMASSD-BOTVIN-S25S3G3
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 49
总计 538
