跳转到主内容
Asus Chromebook Flip C302CA Wi-Fi Card Replacement
Zahid Enriquez
Zahid Enriquez4 其他贡献者
最后更新于 May 25, 2022
4 - 7 分钟
简单
不正确的工具
If your Asus Chromebook Flip laptop (model C302CA) Wi-Fi card has been damaged or you are experiencing connection issues, and you have attempted to troubleshoot them, but nothing works, then you should consider replacing it. This guide will walk you through the steps of replacing your Wi-Fi card.
A Wi-Fi card is a component in the computer that controls the motherboard's connectivity and traffic while determining which components are compatible with the motherboard, such as the CPU, RAM, hard drives, and graphics cards. This is why it is critical to replace it if it is no longer working because it affects your computer's connection.
Make sure your laptop is turned off and unplugged from any outlets before you begin removing the components.
With that in mind, it is best if you gather all of your tools in one location before beginning to replace this component. We recommend that you use the Magnetic Project Mat from iFixit for your screws so that they don't get lost. Choose a location where there will be no children to interrupt you to prevent them from using tools that may hurt them.
你所需要的
工具
查看更多...
  1. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 2 中的图像 1,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 2 中的图像 2,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 2 中的图像 3,3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 3 中的图像 1,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 3 中的图像 2,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 3 中的图像 3,3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 4 中的图像 1,2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 4 中的图像 2,2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: 步骤 5 中的图像 1,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: 步骤 5 中的图像 2,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Battery: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 6 中的图像 1,2 Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 6 中的图像 2,2
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Wi-Fi Card Replacement: 步骤 7 中的图像 1,1
    • Carefully lift up the battery from the front side to remove it from the laptop.
  8. Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: 步骤 8 中的图像 1,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: 步骤 8 中的图像 2,3 Asus Chromebook Flip C302CA Wi-Fi Card Replacement, Wi-Fi Card: 步骤 8 中的图像 3,3
    • Carefully remove the black and white cables connected to the Wi-Fi card.
    • Remove the single 2 mm screw while holding the Wi-Fi card using the Phillips #00 screwdriver.
    • Remove the Wi-Fi card from the laptop.
结论
Zahid Enriquez
于02/08/22注册
543 声望
创作了4篇指南
团队
Gateway, Team 1-2, Saknee Spring 2022 Gateway, Team 1-2, Saknee Spring 2022 的会员
GCC-SAKNEE-S22S1G2
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 443
