Asus Chromebook C202SA-YS02 Display Replacement
简介
转到步骤 1The display includes the entire "top half" of the laptop. If you only need to replace the screen or the bezel, please use those specific guides. If you have structural damage in the display, this guide is for you.
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
this is poo it dont work dont buy it waste of money bad asus or should i say anus?
jodete a tu madre.
im mexican this didnt help me getting over trumps wall so f you
Fold down screen and remove the screen connector band. You may have to use a small flat blade or a spudger, since the latch is very small.
Any tips for getting that tape off? There's some clear plastic tape on the connector with some wickedly strong adhesive. From the black plastic tape that's peeled back a bit on the image, I'm guessing that you also had to peel that off as it goes over top of this, the connector and the nylon or whatever fabric below the connector. I realize that black stuff is just more tape, but still want to avoid making more of a mess than necessary.
I found that working from the side carefully across the tape until it was clear of the black tape underneath worked out ok. Once you're past the edge of the black tape all the way across, it gets easier. Just work carefully until the connector is exposed. I left it from there and didn't try to remove it from the nylon sheath on the display cable, then just smoothed it back down as best as possible once reconnected.
Remove the connecting band from the motherboard. You may have to peel back some tape to be able to access the latch. A small thin blade or spudger might be useful to manipulate the small latch.
You can now remove the display. You may have to use the plastic opening tool to hold the motherboard up while you slide out the display.
另外一个人完成了本指南。
1指南评论
Thank you for this guide. My daughter dropped her Chromebook last week and the display stopped working. I was able to fix it by reconnecting the screen cable to the mainboard.
