跳转到主内容
Asus Chromebook C201 Keyboard Replacement
Robert Lawson
Robert Lawson5 其他贡献者
最后更新于 November 26, 2019
30分钟
中等
If your Chromebook’s keyboard is not working correctly, then this guide is going to help you get your keys working the way they're suppose to. When working on replacing your keyboard, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
你所需要的
工具
查看更多...
  1. Asus Chromebook C201 Keyboard Replacement, Palm Rest Assembly: 步骤 1 中的图像 1,1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
    The feet are self-adhesive and VERY sticky, I found that the jimmy worked better than the spudger.
    MarteB - 回复
  3. Asus Chromebook C201 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
    It's unfortunately easy to accidentally press the power button, Guess how I found that out.... three times. :)
    MarteB - 回复
  5. Asus Chromebook C201 Keyboard Replacement: 步骤 5 中的图像 1,2 Asus Chromebook C201 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Keyboard Replacement: 步骤 6 中的图像 1,3 Asus Chromebook C201 Keyboard Replacement: 步骤 6 中的图像 2,3 Asus Chromebook C201 Keyboard Replacement: 步骤 6 中的图像 3,3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Keyboard Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C201 Keyboard Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Keyboard Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Use a J0 screwdriver to remove the two 3mm JIS 0 keyboard screws.
  10. Asus Chromebook C201 Keyboard Replacement: 步骤 10 中的图像 1,1
    • Pull the tape connecting the keys from the palm rest assembly.
  11. Asus Chromebook C201 Keyboard Replacement: 步骤 11 中的图像 1,2 Asus Chromebook C201 Keyboard Replacement: 步骤 11 中的图像 2,2
    • Gently, with force, pop the keyboard from the palm rest assembly.
    Mine had a metal backing plate which was plastic welded with through holes. It required a little persuasion with a putty knife but I got it.
    Thanks for the guide, I got into it and was looking at those small rivets trying to discern whether they were stand-offs, rivets, 1mm hex, or other - the answer was gently pry off the keyboard.
    Insidious DrNine - 回复
结论
4等其他人完成本指南。
Robert Lawson
于02/09/16注册
841 声望
创作了3篇指南
团队
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G51
4 名成员
创作了10篇指南
2指南评论
Thanks!
Took me about 30 minutes, despite losing a couple of screws (which I did find on the floor/chair), interruptions from kids, and forgetting to put a little rubber pad on the new keyboard, requiring almost complete re-disassembly and assembly.
Only real issue I had was that the old keyboard coming out was basically snapping off little bits of the white keyboard case. (The “gently with force” section.) I suspect that it’s designed as a one-way connection and removal will break those little snaps irrespective of what care is taken. But reassembling it seems to work without those snaps just fine.
Thanks!
Jake - 回复
A couple more notes:
I did it without removing the cable for the touchpad at all. I didn’t see any reason to disconnect that.
After examining the old keyboard more carefully, I realized the plastic sheet on the bottom was removable (it’s just glued on) and should be affixed to the bottom of the old one, so once more I took it apart and added that back. (That sheet had probably saved the computer from killing more than the keyboard when coffee was spilled.)
Also, the two slightly longer screws go under the rubber feet.
Jake - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 22
总计 5,147
