跳转到主内容
Asus Chromebook C201 Battery Replacement
Robert Lawson
Robert Lawson4 其他贡献者
最后更新于 April 8, 2024
没有估计
中等
If your Chromebook is not getting any power, then this guide is going to help you get your power back. When working on replacing your battery, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
你所需要的
配件
工具
查看更多...
  1. Asus Chromebook C201 Battery Replacement, Palm Rest Assembly: 步骤 1 中的图像 1,1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
    The feet are self-adhesive and VERY sticky, I found that the jimmy worked better than the spudger.
    MarteB - 回复
  3. Asus Chromebook C201 Battery Replacement: 步骤 3 中的图像 1,1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Battery Replacement: 步骤 4 中的图像 1,1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
    It's unfortunately easy to accidentally press the power button, Guess how I found that out.... three times. :)
    MarteB - 回复
  5. Asus Chromebook C201 Battery Replacement: 步骤 5 中的图像 1,2 Asus Chromebook C201 Battery Replacement: 步骤 5 中的图像 2,2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Battery Replacement: 步骤 6 中的图像 1,3 Asus Chromebook C201 Battery Replacement: 步骤 6 中的图像 2,3 Asus Chromebook C201 Battery Replacement: 步骤 6 中的图像 3,3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Battery Replacement: 步骤 7 中的图像 1,2 Asus Chromebook C201 Battery Replacement: 步骤 7 中的图像 2,2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Battery Replacement, Battery: 步骤 9 中的图像 1,2 Asus Chromebook C201 Battery Replacement, Battery: 步骤 9 中的图像 2,2
    • Use a J0 screwdriver to remove the seven 4mm silver heat shield screws and remove the heat shield.
  10. Asus Chromebook C201 Battery Replacement: 步骤 10 中的图像 1,1
    • Pull the battery cable from the motherboard.
  11. Asus Chromebook C201 Battery Replacement: 步骤 11 中的图像 1,1
    • Use a J0 Phillips screwdriver to remove the 5, 4mm silver battery screws from the battery.
  12. Asus Chromebook C201 Battery Replacement: 步骤 12 中的图像 1,1
    • Grab the the battery and remove it from the Chromebook.
结论
9等其他人完成本指南。
Robert Lawson
于02/09/16注册
841 声望
创作了3篇指南
团队
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 的会员
USFT-CAGLE-S16S2G51
4 名成员
创作了10篇指南
2指南评论
This was a great guide to replacing the battery in the ASUS chromebook C201 PA. I left the instructions displayed on my regular lap top as I went thru the steps. There was a trick when it came to disconnecting the keyboard plugs. The tabs that were supposed to be bent up to enable the unplugging weren’t there and rather than fiddle around trying to unplug them in some other way I just left them connected and manipulated the key board very carefully when needed. A second set of steady hands can help.
Doug Hooper - 回复
I first looked for a YouTube video for info, silly me. They showed removing the lid and disconnecting all the accompanying cables! It didn’t look necessary to me, and as this guide shows, it isn’t.
I do find it curious as it looks to me like the lid is lying flat, I wonder if the author loosened or removed the lid hinge screws to allow that. That might simplify things.
The battery failed in mine, I’m debating whether or not it’s worthwhile to replace in a five year old device that cost $200ish to originally purchase.
Wayne West - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 34
总计 4,582
