跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
Apple Watch Series 3 电池更换
你所需要的
  1. Apple Watch Series 3 电池更换, 打开显示屏: 步骤 1 中的图像 1,1
    • 准备iOpener,并加热显示屏以软化粘合剂,将其固定到位。
    I have heated up the iOpener to 165 degrees and left it on for more than a minute. No way I can lift the screen off with the exact knife. Tried different angles in various places, but no go. I also used a hair dryer un til the watch screen was too hot to touch and even tried a very hard cutting tool blade and also no go. Could n ever get the blade under the face I applied enough force where I could see that the blade left small marks, not very big, but could never get anything to move or lift. What am I doing wrong? I spent 47 years at a global computer company and I am used to taking apart small things and applying force when required. I don’t know what I am doing wrong. Please help me.
    Rafael Blanco - 回复
    Getting the initial gap is not easy. Maybe a playing card could work its way in the tiny gap and cut some adhesive. After that there might be some success with an exacto knife. Or you want to try a piece of aluminum foil (folded for more rigidity) for cutting the adhesive. Be aware of the force touch gasket and that it might get damaged during that procedure.
    Tobias Isakeit -
    I finally used a hot air gun set to 150 deg. C heating up the edges by slowly spinning the watch around before the technique worked. Difficult is the level noted and it’s correct. Finally worked and watch perfectly functioning.
    Chris Giavotto - 回复
    I used a heat gun, too. I was worried after reading comments that it would burn up the LCD, so I heated it a little bit at a time, rotating it like you did, and checking to see if I could get my knife under it. I must have hit one of the buttons because it did turn on, but that did reassure me that the display was okay.
    It's open. Now that the watch and I have had a few minutes to cool down, I'm ready for the next step. Not as difficult as I thought it could be. Tomorrow, I'll be replacing the battery in an iPod Touch 6th Gen.
    bester -
    I had to heat the iOpener 2 times and leave it on top of the watch for 10 minutes.
    Axel Trujillo - 回复
  2. Apple Watch Series 3 电池更换: 步骤 2 中的图像 1,3 Apple Watch Series 3 电池更换: 步骤 2 中的图像 2,3 Apple Watch Series 3 电池更换: 步骤 2 中的图像 3,3
    • 始终保持手指完全远离刀。 千万不要施加太大的压力,因为这可能会导致刀滑动并切割或损坏手表。
    • 仅将刀片的细边插入间隙,然后朝您的方向倾斜刀片以加宽间隙,并将显示屏略微抬起。
    • 将弯曲刀片的边缘放入显示器和外壳之间的薄间隙中。 从显示屏的短边开始,最靠近圆形圈。
    • 不要将刀插入1/16英寸(约2毫米)。
    It’s difficult to grip case in a way that keeps fingers safe from the blade but doesn’t hit the side buttons and turn the device on!
    If it’s a struggle to get the display to release, warm case for a few more minutes.
    Kyle Powderly - 回复
    I have tried so may times to get the display to release but nothing works. Should have bought a new watch LOL. Kept the iOpener on 2 times for 10 minutes and it still won't open. There must be a better way.
    Susan E. White - 回复
    Hi Susan,
    if you're struggling to get the adhesive loose enough a hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Dominik Schnabelrauch -
  3. Apple Watch Series 3 电池更换: 步骤 3 中的图像 1,2 Apple Watch Series 3 电池更换: 步骤 3 中的图像 2,2
    • 一旦使用刀片打开了小间隙,请移除刀片并将打开工具的较薄边缘插入间隙中。
    • 在此插入翻译将开口工具推入间隙,用拇指作为支点,将显示屏再打开一点。
    • 现在不要试图完全分离显示屏。 Force Touch垫圈可能会粘在显示器或机身上,如果用力过猛,可能会被撕裂。
  4. Apple Watch Series 3 电池更换: 步骤 4 中的图像 1,3 Apple Watch Series 3 电池更换: 步骤 4 中的图像 2,3 Apple Watch Series 3 电池更换: 步骤 4 中的图像 3,3
    • 在显示屏下方插入一个开口拨片,小心地将Force Touch垫圈与显示屏分开。
    • 确保您找对了位置。 如果在抬起显示屏时把Force Touch垫片分离了,或者您将垫圈层分开,则还需要更换Force Touch垫圈本身。
    • 在显示屏周围滑动拨片以分离Force Touch垫圈和显示屏之间的粘合剂。
    • 不要将开口拨片插入深度超过1/16英寸(~2 mm)。
  5. Apple Watch Series 3 电池更换: 步骤 5 中的图像 1,3 Apple Watch Series 3 电池更换: 步骤 5 中的图像 2,3 Apple Watch Series 3 电池更换: 步骤 5 中的图像 3,3
    • 为避免损坏显示屏电缆,请勿完全打开显示屏。
    • 将显示屏打开约45°角,然后用镊子剥去显示屏和Force Touch垫圈之间的粘合剂。
    • 将粘合剂穿过显示器电缆的周围和后面,使其完全脱落,然后向下按压垫圈以重新粘附到盒子上。
    • 如果Force Touch垫圈本身松动且不会向下弯曲,则应更换垫圈下方和垫圈与显示屏之间的粘合剂。
  6. Apple Watch Series 3 电池更换, 断开电池连接: 步骤 6 中的图像 1,3 Apple Watch Series 3 电池更换, 断开电池连接: 步骤 6 中的图像 2,3 Apple Watch Series 3 电池更换, 断开电池连接: 步骤 6 中的图像 3,3
    • 卸下固定金属盖板的Y型#000螺丝。
    • 用一把镊子取下盖板。
    • 首先打开盖板。
    • 然后将其关闭一半,将其完全取出。
    Pictures are the GPS version. Cellular doesn’t have the gap and separate removable plate on the “taptic engine” section.
    Ryan Holt - 回复
    What if I’m unable to unscrew the screw? I’m using the right tool, but it just won’t do it. It feels like it can’t “lock in” if you know what I mean in order to be able to get enough grip to turn the screw. Any suggestions?
    Cade Capper - 回复
    Once you have the driver set properly in the screw you have to lean into it to get it to turn. The screw is coated with LockTight.
    mailghall - 回复
  7. Apple Watch Series 3 电池更换: 步骤 7 中的图像 1,3 Apple Watch Series 3 电池更换: 步骤 7 中的图像 2,3 Apple Watch Series 3 电池更换: 步骤 7 中的图像 3,3
    • 在仅有GPS的版本上,可以在卸下金属板后立即断开电池。 对于LTE版本,你首先需要断开Force Touch垫圈并将其折叠,以便断开电池连接。
    • 使用撬棒的尖端直接向上撬起连接器来断开电池连接。
    • 稍微弯曲连接器,确保它不会意外接触到主板。
    whats does it happen if the connector make contact by accident????
    Daniel Sanchez - 回复
  8. Apple Watch Series 3 电池更换, 电池: 步骤 8 中的图像 1,3 Apple Watch Series 3 电池更换, 电池: 步骤 8 中的图像 2,3 Apple Watch Series 3 电池更换, 电池: 步骤 8 中的图像 3,3
    • 使用撬棒的平端在电池和电源按钮旁边的框架之间撬动。这样,在拉出电池时,不要挤压或折叠任何电缆。
    • 缓慢但稳定地提起电池,使其与下面的粘合剂分离,将其固定到位。
    • 确保不要刺破电池或使电池变形,因为如果电池损坏可能会着火和/或爆炸。
    • 取出电池。
    • 请参阅结论中的粘合剂更换指南,以便在重新组装时使用新的粘合剂。
    I had some regular sized (old ifixit) guitar picks and that worked well too.
    amiller770 - 回复
    I was able to make one out of a soda bottle and got the battery out with no damage
    Dylan Chapell - 回复
结论
安装新电池后,你可以打开手表进行测试,然后再将其粘合。要重新组装设备,请将其关闭,然后按逆序执行这些说明。在使用新的粘合剂之前,务必取下显示器背面和垫片顶部的旧粘合剂,如粘合剂更换指南所示。
60等其他人完成本指南。
由衷感谢以下译者:
en zh
83%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tobias Isakeit
于03/31/14注册
117,598 声望
创作了188篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
9条评论
Hi
I’m having problem with my Apple Watch series 3, a red snake shown in the watch, I bought a brand new battery here in ifix and i proceed to install it but I’m having the same problem. Can someone help me.
thanks
educroasdaile - 回复
Have you checked our Apple Watch troubleshooting page for the charging issue?
Tobias Isakeit -
followed all the steps properly. But the Apple watch does not switch on! The new battery does not seem to work.
Karthikeyan Rathinasamy - 回复
After replacing the Battery will the watch be waterproof enough to swim with/ have the same water resistance as when it was new
Gibson White - 回复
If you cleaned both the backside of the lens and the case groove where the adhesive was very well and replaced the adhesive getting it squarely on the case lip just as the original one was installed, I would expect the watch to be as sealed and water resistant as it was when new.
Bill Auerbach -
There seems to be a lot of talk about the force touch gasket, but given apple removed support for force touch anyways, is it ok to just remove the gasket altogether? or will that effect the fit of the parts and effect water resistance?
Bob - 回复
Hi Bob,
removing the force touch gasket will lower your screen accordingly deeper into the housing (we noticed that with the next iteration being a tad thinner). So you might feel a little ridge when touching the edges of the display during use. Water resistance will be the same as when you have the force touch gasket or not.
Tobias Isakeit -
FYI for whoever this might help, I just took apart my cellular series 3 watch, this one is from the first year of the series 3 (when it was the newest watch). There were 2 differences, one of them didn't matter, but one of them was of critical importance.
I bought the iFixit kit for this battery replacement. One, rather than the panel being a separate black panel like in the pictures here, it was one continuous black sticker I had to peal up.
Secondly, the side panel that they say to use a Y000 screwdriver on, I tried using the Y000 tip included in my iFixit kit, AND IT DID NOT FIT. luckily I had a few tri point drivers around so I was able to undo it, but they are not labeled, so that doesn't help anyone else in this situation.
Benjamin kier - 回复
Ist die Batterie auch für die Apple Watch SE 40mm geeignet?
Für eine Rückmeldung/Antwort danke ich vorab.
Lilly Besson - 回复
添加评论
浏览统计数据:
过去 24 小时: 48
过去 7 天: 350
过去 30 天: 1,616
总计 106,739
