跳转到主内容
加入维修社区 - 创建账户
Apple Powerbook 5300 Hard Drive Replacement
你所需要的
    1. Apple Powerbook 5300 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement, Battery: 步骤 1 中的图像 2,2
      • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
      • Press the battery removal latch located on the right side of the front panel.
      • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
      • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
      询问修复机器人
      添加评论
    1. Apple Powerbook 5300 Hard Drive Replacement, Keyboard: 步骤 2 中的图像 1,1
      • For the next step you are to grab the TR8 Torx Security Screwdriver
      • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
      • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
      询问修复机器人
      添加评论
    2. Apple Powerbook 5300 Hard Drive Replacement: 步骤 3 中的图像 1,1
      • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
      • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
      • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
      添加评论
    1. Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
      • Gently lift up the laptop's front-most panel and slowly raise the trackpad from the logic board.
      • Disconnect the front panel's ribbon cable from the board by slowly pulling it out of the connection port. Set the panel aside.
      询问修复机器人
      添加评论
    2. Apple Powerbook 5300 Hard Drive Replacement: 步骤 5 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement: 步骤 5 中的图像 2,2
      • Unscrew the Torx #8 screws holding the hard drive case in place on the logic board.
      • Lift up on the hard drive to disconnect its ribbon cable from the logic board, just like in the previous steps.
      询问修复机器人
      添加评论
    3. Apple Powerbook 5300 Hard Drive Replacement: 步骤 6 中的图像 1,2 Apple Powerbook 5300 Hard Drive Replacement: 步骤 6 中的图像 2,2
      • Unscrew the four Torx #8 screws holding the hard drive to its case.
      • The hard drive can now be removed from its encasement.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Scott
于04/26/11注册
155 声望
创作了5篇指南
团队
Cal Poly, Team 25-30, Garner Spring 2011 Cal Poly, Team 25-30, Garner Spring 2011 的会员
CPSU-GARNER-S11S25G30
4 名成员
创作了12篇指南
1指南评论
I was very surprised to find this guide and very pleased. Good work.
mayer - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 53
总计 7,178
