跳转到主内容
加入维修社区 - 创建账户
Anker SoundCore 2 Charging Port Replacement
你所需要的
  1. Anker SoundCore 2 Charging Port Replacement, Front Panel: 步骤 1 中的图像 1,2 Anker SoundCore 2 Charging Port Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    添加评论
  2. Anker SoundCore 2 Charging Port Replacement, Motherboard: 步骤 2 中的图像 1,3 Anker SoundCore 2 Charging Port Replacement, Motherboard: 步骤 2 中的图像 2,3 Anker SoundCore 2 Charging Port Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
    询问修复机器人
    添加评论
  3. Anker SoundCore 2 Charging Port Replacement: 步骤 3 中的图像 1,3 Anker SoundCore 2 Charging Port Replacement: 步骤 3 中的图像 2,3 Anker SoundCore 2 Charging Port Replacement: 步骤 3 中的图像 3,3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
    添加评论
  4. Anker SoundCore 2 Charging Port Replacement, Charging Port: 步骤 4 中的图像 1,2 Anker SoundCore 2 Charging Port Replacement, Charging Port: 步骤 4 中的图像 2,2
    • Desolder the charging port from the motherboard and solder a new one on.
    • For help with soldering and desoldering, follow this guide.
    添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
5指南评论
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - 回复 分享
Where can i get a replacement charging Port?
A K - 回复 分享
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - 回复 分享
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - 回复 分享
I use Anker OEM style replacement in my repair shop from eBay listing 254057783007
Perfect fit.
https://www.ebay.com/itm/254057783007
Good luck with the project
G.K. - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 130
总计 5,400
