跳转到主内容
加入维修社区 - 创建账户
Anker SoundCore 2 Bluetooth Chip Replacement
你所需要的
  1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: 步骤 1 中的图像 1,2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: 步骤 1 中的图像 2,2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    添加评论
  2. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: 步骤 2 中的图像 1,3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: 步骤 2 中的图像 2,3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
    询问修复机器人
    添加评论
  3. Anker SoundCore 2 Bluetooth Chip Replacement: 步骤 3 中的图像 1,3 Anker SoundCore 2 Bluetooth Chip Replacement: 步骤 3 中的图像 2,3 Anker SoundCore 2 Bluetooth Chip Replacement: 步骤 3 中的图像 3,3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
    添加评论
  4. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: 步骤 4 中的图像 1,2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: 步骤 4 中的图像 2,2
    • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
    • For help desoldering and soldering, follow this guide.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
1指南评论
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 20
过去 30 天: 77
总计 2,948
