跳转到主内容
加入维修社区 - 创建账户
Anker 2.4G Wireless Mouse Left and Right Button Replacement
你所需要的
    1. Anker 2.4G Wireless Mouse Left and Right Button Replacement, Left and Right Buttons: 步骤 1 中的图像 1,1
      • Peel off the stickers. This will reveal the location of four screws.
      询问修复机器人
      添加评论
    2. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 2 中的图像 1,1
      • Remove the four screws using a Phillips #0 screwdriver.
      询问修复机器人
      添加评论
    3. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 3 中的图像 1,2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 3 中的图像 2,2
      • Use a spudger to pry apart the upper and lower housing of the mouse.
      询问修复机器人
      添加评论
    4. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 4 中的图像 1,1
      • Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
      • Pull as far up on the wires as possible. Be careful not to rip the wires by applying too much force.
      询问修复机器人
      添加评论
    5. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 5 中的图像 1,1
      • Remove the scroll wheel from the mother board by pulling it to the left.
      • This may take some force to remove. Make sure to pull the scroll wheel parallel to the board, not perpendicularly.
      询问修复机器人
      添加评论
    6. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 6 中的图像 1,1
      • Pull the mother board gently away from the plastic housing.
      询问修复机器人
      添加评论
    7. Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 7 中的图像 1,2 Anker 2.4G Wireless Mouse Left and Right Button Replacement: 步骤 7 中的图像 2,2
      • Desolder the components and re-solder the replacements in order to repair the left and right buttons.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
2等其他人完成本指南。
Vincent Lee
于01/23/14注册
365 声望
创作了3篇指南
团队
Cal Poly, Team 1-39, Maness Winter 2014 Cal Poly, Team 1-39, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G39
4 名成员
创作了64篇指南
2指南评论
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
jacques gates - 回复 分享
where can these replacement button switches be purchased….thanks ric
Ric Scambler - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 38
总计 5,279
