跳转到主内容
Acer Aspire One ZG5 Hard Drive Replacement
Doug Gallatin
Doug Gallatin7 其他贡献者
最后更新于 February 9, 2024
20分钟
中等
Use this guide to replace the hard drive in the Acer Aspire One ZG5. After removing the motherboard, the hard drive is easy to replace.
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
工具
查看更多...
  1. Acer Aspire One ZG5 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Hard Drive Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 8 中的图像 1,1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
    mi lap NO tiene wireless card
    gustavo cordova - 回复
  9. Acer Aspire One ZG5 Hard Drive Replacement, Keyboard: 步骤 9 中的图像 1,1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  10. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 10 中的图像 1,3 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 10 中的图像 2,3 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 10 中的图像 3,3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  11. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 11 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 11 中的图像 2,2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  12. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 12 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 12 中的图像 2,2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
    my keyboard ribbon face damaged. how to repair?
    musa musa - 回复
  13. Acer Aspire One ZG5 Hard Drive Replacement, Top Case: 步骤 13 中的图像 1,1
    • Close the display and turn the ZG5 over so that the battery compartment faces away from you.
  14. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 14 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 14 中的图像 2,2
    • Remove three 5.8 mm Phillips #0 screws from the bottom of the case
    • Remove three 3.9 mm Phillips #1 screws from the battery compartment.
    • Remove two 5.8 mm Phillips #0 screws from underneath the feet near the hinges.
  15. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 15 中的图像 1,1
    • Turn the netbook back over and open the display with the keyboard cavity facing you.
  16. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 16 中的图像 1,3 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 16 中的图像 2,3 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 16 中的图像 3,3
    • Flip up the retaining flap on the trackpad ribbon cable ZIF connector.
    • Using the blue tab, pull the trackpad ribbon cable from its socket on the motherboard.
  17. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 17 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 17 中的图像 2,2
    • Remove the five black 4.7 mm Phillips #0 screws from the metal casing.
    • Remove the single silver 4.3 mm Phillips #00 screw from the right side of the metal casing.
  18. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 18 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 18 中的图像 2,2
    • Starting at the red rings along the hinge, insert a spudger or plastic opening tool into the seam between the two halves of the case.
    • Slide the spudger toward the front of the device, releasing the small clips that hold down the top case.
    • Gently lift off the top case.
  19. Acer Aspire One ZG5 Hard Drive Replacement, Internal Wireless Card: 步骤 19 中的图像 1,1
    • Disconnect the two antenna cables from the right side of the wireless card.
  20. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 20 中的图像 1,1
    • Remove the single 3.9 mm Phillips #1 screw from the wireless card.
  21. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 21 中的图像 1,1
    • Gently pull the wireless card to the right and slide it out of its socket.
  22. Acer Aspire One ZG5 Hard Drive Replacement, Motherboard: 步骤 22 中的图像 1,1
    • Disconnect the display cable from the top left of the motherboard.
  23. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 23 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 23 中的图像 2,2
    • Disconnect the speaker cable from its socket on the motherboard.
  24. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 24 中的图像 1,1
    • Remove three 3.9 mm Phillips #1 screws from the small I/O board.
    • Remove a single 3.9 mm Phillips #0 screw from the front of the motherboard.
    • Some laptops may instead have a single 4.7 mm Phillips #0 screw.
  25. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 25 中的图像 1,1
    • Remove the two 4.7 mm Phillips #1 screws that connect the display to the motherboard.
  26. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 26 中的图像 1,1
    • Gently lift the I/O board up from the right side of the case.
    • The I/O board is attached to the motherboard by a short cable.
    I took apart an SSD variant. At this step, there were two screws holding the SSD down, but the SSD did not come out with the main and daughter boards. Detaching the I/O cable freed the mainboard to come out with or without the daughterboard.
    unixusr - 回复
    there are 2 silver screws that need to be removed in this step your picture shows them still installed (one is located neer audio plug, the other is located neer keyboard plug) in step 27 (next step) they have been removed without mention
    Scott Riley - 回复
    I have added 1 gb of memory to my ZG5 thanks to this helpful guide. Total cost, including a spudger and a new mini screwdriver, to tackle the 00 Philips, GBP 17.57
    I fear I haven't put the trackpad connector back properly, but device works great with a wireless mouse. Very many thanks.
    John Serocold - 回复
  27. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 27 中的图像 1,1
    • Lift the entire motherboard assembly out the case.
  28. Acer Aspire One ZG5 Hard Drive Replacement, Hard Drive: 步骤 28 中的图像 1,1
    • Turn the motherboard over so that the RAM is facing up.
  29. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 29 中的图像 1,2 Acer Aspire One ZG5 Hard Drive Replacement: 步骤 29 中的图像 2,2
    • Disconnect the I/O board from the motherboard.
    This step (29) isn’t required to remove the hard disk drive.
    montazmeahii - 回复
  30. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 30 中的图像 1,1
    • Remove the two 4.7 mm Phillips #0 screws that hold down the hard drive.
    La notebook trae el disco duro en la parte de atrás? Por dónde va el ventilador?
    Julio Cesar Roman Gonzalez - 回复
  31. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 31 中的图像 1,1
    • Pull the hard drive straight out from the motherboard.
  32. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 32 中的图像 1,1
    • Remove the four 3.9 mm Phillips #1 screws from the hard drive casing.
    • There are two screws on each side of the casing.
  33. Acer Aspire One ZG5 Hard Drive Replacement: 步骤 33 中的图像 1,1
    • Remove the upper and lower casing from the hard drive.
结论
110等其他人完成本指南。
Doug Gallatin
于10/05/10注册
6,337 声望
创作了10篇指南
团队
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G49
5 名成员
创作了27篇指南
14条评论
Excellent guide. This "student" should be promoted to "instructor" right away. Many thanks.
Rudy Fernandes - 回复
This guide helped a lot with refurbishing my old ZG5. It now has a case that is not cracked, 1.5 GB memory, and a 240GB SSD. I get to put off Windows 10 for a while longer.
James Stallings - 回复
Thanks a lot! i already upgrade memory from 1 to 1.5 on my acer. But i have a question, does the aoa 150 works faster with a ssd disk? i want to try with one of 240 gb. Anyone try it?
Martiniano Vera Enrique - 回复
Not the easiest upgrade I've ever done (perhaps the most difficult, actually), but I got it done. Removing the keyboard was the trickiest step for me. Be patient. If you can work one of the corner releases, you can put a flat-blade screwdriver under the corner of the keyboard and work on the other releases (starting at the far corner, then the centre).
The other tricky problem I had was getting the little ribbon cable for the trackpad properly reconnected after completing the project. (I thought the keyboard cable would be the tricky part, but it turns out to be pretty easy.) Be patient and you'll be fine. You may want to test (with a mouse handy) before you reinsert the keyboard.
Thanks very much for this howto!
Jim MacKenzie - 回复
I had one of these little beasts that my son gave away about 6 years ago. The person he gave it to returned it to him a month later because it would not turn on. It was a case of the boot sector problem that plagues the ZG5. I performed the repair described on the Acer web site and it has been running fine ever since. After installing Linux Mint (dual boot), it was finally given away again last summer. Now it seems it is coming back to me. This might be the time to upgrade it with an SSD. Thanks for this tutorial. I will probably be making use of it over the next few weeks.
Chuck Pilger - 02/23/2017
Chuck Pilger - 回复
Ok I'm ready to take the plunge and install an ssd. Which version of Win 10 works well? Or, how about win7, which I always liked? Pete Lunde 07/13/2017
Quasimodo - 回复
I tried both Windows 7 and 10. I'd say to upgrade the memory to max (1.5GB) before trying to run ANY version of Windows. Also, while 7 ran nicely enough with that upgrade, I think Linux works even better. Windows 10 (32-bit, of course) runs, but it was way too slow to be comfortable for me to use. Of course, Windows 10 has more built-in protections against malware, so there are trade-offs to consider. If you don't *need* to run any Windows-only apps, though, at least try Linux on a Live USB and see how you like it.
pacmanmaster -
I used this guide to upgrade the hard drive, upgrade the memory (from 1GB to 1.5GB), and replace a busted internal WiFi card (upgrading from 802.11g to 802.11n in the process!). It can be done, but I will say that removing the keyboard is harder than it should be. In doing so, I broke one of the clips that holds it in. It still works great, but the keyboard now bounces a little. Be careful with that step!
Overall, considering that the ease of replacing these three parts once opened, it's a shame that Acer made it so HARD to open (safely).
I installed Windows 7 when I upgraded it, and it ran fine (but a bit pokey). I upgraded to Windows 10, and it worked, but it was even slower. After I migrated away from using apps on this machine that required Windows, I installed Linux Mint exclusively (had it dual-booting before), and it works better than it did with either Windows 7 or 10. (Note: To insure Linux compatibility, I used an Intel-branded WiFi card, which I checked for compatibility beforehand).
pacmanmaster - 回复
Parts list shows SSDs compatible with MAC computers, are they also compatible with Aspire one ZG5?
Johnson - 回复
I would like to replace the HDD with an SDD. Are there any specific SDDs that would work best for the MB Connection?
scottfabo01 - 回复
Scott, I assume you mean SSD, which stands for Solid-State Drive, and not SDD (whatever that stands for).
Michael Walsh -
Many thanks for this guide. I was able to replace the disk without any problem
Marco Manna - 回复
Its 2024, following your excellent instructions I have just successfully replaced my aging hdd with a new ssd. Many Thanks
barneeyebay - 回复
I've got LMDE 32bit running on my Aspire One for Amatuer Radio use. Following the guide to upgrade both the memory and the original 120G HD with a SSD. This is a fantastic guide to disassembly. I'm the original owner and it's got 16 year old dust that needed cleaning out as well. Thank You!
Lewis Burmeister - 回复
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 48
过去 30 天: 170
总计 281,138
